Author Topic: tiny tremoloOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO  (Read 367224 times)
MetalUpYerEye
Re: tiny tremoloOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
« Reply #280 on: November 29, 2010, 07:06:06 PM »
Sounds like its popping because i'm connecting my signal + with my signal ground. Pops every time the LED turns on...
I don't really know if this could be the issue, but have you considered the possibility that your LDR gets way to much light? If the resistance suddenly goes to near zero you are essentialy connecting your signal+ to your signal ground. Slide your sunglasses between the led and the LDR and see what happens, if you haven't rewired it yet that is, you've rewired this one more than most I guess  :icon_mrgreen:
I had thought of this but i've already tried a resistor in parallel (like a 5k with my LDR to lower the max resistance and it still pops.
I'm pretty spent on this circuit. Never has such a simple design had its foot so far up my ass.
JRM
« Reply #281 on: November 30, 2010, 05:59:42 AM »
I've tried the Danelectro Tremolo. True By-pass and nice but I prefer your sound clip. The Danelectro has depth and chop (hard/soft) controls plus, of course, the rate/speed control. I prefered the more chopy one and I've found pointless to play with the depth pot as things got "muddy" appart from a very limited range. At some speeds the cut was just too strong not making a nice effect. And when we desengaged the effect, the volume went up (a lot!). The clip I've heard from yours makes the effect I wanted. I've already read about the ticking issues but I haven't fully uderstood how can we manage to have different grounds when we feed the two circuits from the same power source: no matter what you do, they'll always touch each other at the baterie or psu neg terminal.
No no no no.
Why is no one understanding this?
the in/out jacks do not have to be connected to the battery or power psu terminals. they need only be connected to each other, with the ground terminating in the amp. The jack grounds are connected to each other via the aluminum enclosure, and pass right on through to be grounded down the line. This way, the power ground being utilized for the circuit doesn't ever touch the signal.
Didn't we just have a thread about this?
You're right. I've solved this yesterday at the subway on my way back home but had no opportunity to post it here. In fact it's easy: it's just to put the ldr in series with the signal wire from the in and out jack (and the depth pot if one want to). And then build the pulsing led circuit independently. A DPDT switch will enable true bypass with a led (the rate led).
« Reply #282 on: November 30, 2010, 06:11:56 AM »
anyone good at diagrams?...would be helpful to all in future i'm sure..... 8)
JRM
« Reply #283 on: November 30, 2010, 06:24:05 AM »
I can do it, but i'm not shure when. Today's night if I get lucky. I'll use the last one posted. What program do you prefer: PCB express, Eagle or Easy DIY?
« Reply #284 on: November 30, 2010, 06:28:24 AM »
great .easy diy...thanks, i havent the time at the moment...
Perrow
« Reply #285 on: November 30, 2010, 11:27:42 AM »
If I get lucky tonight, I'll draw no bleeding schematic I'll tell you that much  :icon_cool:
« Reply #286 on: November 30, 2010, 11:41:38 AM »
IF... you get lucky.... :icon_mrgreen:
Perrow
« Reply #287 on: November 30, 2010, 12:59:50 PM »
Well, you just see if I draw any schematic.
Of course, I could fake it and just not draw anything  ::)
« Reply #288 on: November 30, 2010, 01:07:16 PM »
no cheating..... :icon_wink:
Perrow
« Reply #289 on: November 30, 2010, 01:08:28 PM »
No cheating ???
How would I "get lucky" without cheating  ???
JRM
« Reply #290 on: December 01, 2010, 05:37:55 AM »
 ;D you must remember that my English is not perfect! After I've post that I tought it sounded funny but didn't remember why...
It seems I got "too lucky" so I've done it this morning (it's a holiday here in Portugal). Can anybody help me to upload it? Or I can send it by e-mail to someone who can upload it
« Reply #291 on: December 01, 2010, 05:49:17 AM »
jrm pm'd....
jrm kindly posted this to me..heres his version...i just tweaked the size... :icon_wink:
is the wiring on the depth pot right?..looks a little strange to me...?
shouldn't it be wired more like this?..hmmmm...but then it would cut the volume wouldnt it????...
« Last Edit: December 01, 2010, 07:28:50 AM by deadastronaut »
JRM
« Reply #292 on: December 01, 2010, 11:08:12 AM »
In fact, I had doubts about the depth pot as your schem had an odd wiring with the in and out together and the LDR and depth pot in paralel with them.
I've sent you a version with a DPDT switch, but I still don't know how should we wire the depth pot.
Perrow
« Reply #293 on: December 01, 2010, 02:59:01 PM »
No worries, neither's mine and I think that most of us let those slip from time to time (even native speakers). I just couldn't let this one slip by unnoticed.
And by the way, I think the depth pot will only work for "bleed" mode. Where you can control the amount bled away. For inline, I think even the dimmed led configuration is just a volume control, as the dark resistance is the higher resistance dimming the led will only lower the volume. But wait (and I've come to this conclusion before  :icon_rolleyes:), what you could do is put the pot parallel with the ldr, that way you can control the dark resistance. You'll probably need a high resistance pot though.
Edit: grammar :)
« Last Edit: December 01, 2010, 03:00:32 PM by Perrow »
MetalUpYerEye
« Reply #294 on: December 01, 2010, 06:50:23 PM »
I tried the depth pot both ways (dimming the LED with inline and bleed to ground on the LDR) and I never heard a really audible difference.
The switching for this has to be done on a DPDT. You can't turn the circuit on and off via the input jack without connecting the grounds and you can't switch the circuit by itself because your LDR is in the dark and won't allow any signal through...
JRM
« Reply #295 on: December 02, 2010, 08:53:24 AM »
Can someone try to wire the depth pot in paralel with the LDR? Try it with the higher resistance pot that you have available. I think it will work that way, making a blend between the clean (through the pot) and the "tremoled" (through the ldr) signal. I just don't have the parts to do it.
illidan
« Reply #296 on: December 03, 2010, 02:10:55 AM »
i thought eagle is preferable... thanks...
and show it on page 1...
coz,, i've failed to build it... :D
JRM
« Reply #297 on: December 03, 2010, 06:26:29 AM »
Eagle is nice for pcb drawing but we already have a pcb for this circuit. Just check around page 3. As this circuit is so small it's cheaper to do it on a small stripboard.
JRM
« Reply #298 on: December 15, 2010, 11:28:32 AM »
I'm preparing an order of missing components so I  need to make somehing clear:
One can't use a superbright 3mm blue led as a rate indicator led at this circuit can we? I think I've read it somewhere along the 15 pages of the thread but I don't remember if that's right and why.
Manny
« Reply #299 on: December 15, 2010, 03:30:46 PM »
Hi JRM,
I'm using a 3mm superbright for the rate LED on mine. I built it as per my hand drawn effort a few pages back, adjust the resistors as needed.
One thing to note if using that schematic is that there's a rogue ground connection that needs to be omitted, it's the one furthest to the left after the LEDs.
Hope this helps  :)
