(6) AA batteries vs (1) 9V battery
Started by Philippe, October 05, 2010, 04:43:16 PM
StephenGiles
I don't think you will find 110volts AC anywhere in Europe - 230 volts is now regarded as world standard. It's just that the USA does not comply :icon_lol: :icon_lol: :icon_lol:
armdnrdy
#21
Quote from: StephenGiles on July 06, 2013, 07:10:44 AM
We are the original "Punk rockers" without the music!
Thecomedian
Quote from: CynicalMan on October 06, 2010, 05:16:15 PM
True, but for someone who is more into distortions/ODs/wahs rather than Whammys or HOGs, this could be useful. Cost is also an issue with these. I wouldn't pay $150 to be able to use an AC outlet later than sooner when I can buy a 1spot for $20.
It would be nice to have a battery pack with more capacity. If I knew more about charging Li-ions I might buy 10 or 20 of those cell phone batteries and make a battery pack at something like 5000mAh.
666 posts  :icon_twisted:
buy a battery for an electric car. mobile high voltage/mAh and no need for wall power. And you can recharge it.
If I can solve the problem for someone else, I've learned valuable skill and information that pays me back for helping someone else.
the terminal voltage of NiMH and NiCd is 1V2, no? 6 * 1V2 = 7V8. this is a cause for disappointment when buying a "9V NiCd battery". 8 batteries would be a different story.
greaser_au
Quote from: duck_arse on July 06, 2013, 08:13:25 AM
the good ones are actually made with 7 cells, and were not at all uncommon   :)    However as luck would have it, the ones I had from the 'old days' are only six...
mac
Quoting myself:
QuoteI you had enough space inside your box 6 x 1.5v aa/aaa batteries will last a long long time, maybe years if you power a FF, Big Muff, dist+ or similar, depending on how often you use them.
I power my pedals this way if I can get a large box. The batteries in my Rangemaster and Fuzz Faces are 3 years old or so.
The ONLY problem you must be aware of is that sometimes after a long period of time batteries could begin to leak, so you must check your pedals from time to time.
5 years now.
The packs of my Rangemaster and FF read 9.5v, and look ok  ;)
For all others pedals, instead of a PS I have a metal box with shielded wire holding 6xD cells.
As an example, I built 386 amps to amplify MP3 players for beach use. I had to replace 6xAA after a month or two using it a couple of hours a day. Today I use rechargeable batts.
1W @ 9v is about 111mA, full volume.
mac
Joe
Yeah my manual says 100V-240V, should not be a problem. :icon_mrgreen:
