This 10-pin board should work great for that, and it'is easy to use.
See
http://sites.google.com/site/nextaudiodsp/Cost is around $35. Email me at mark.seel@gmail.com
There has been some people interested and I'm getting ready to build a batch (sorry it's taking so long)
The 10-pin DSP board has:
- Stereo analog inputs and outputs (unbuffered, direct path to ADC and DAC)
- Power supply, ground and programming pin
- Three pins for pots.
There will also a 10-pin companion board (doing the PCB right now!) with:
- Mini Type-B USB connector and USB/Serial converter
- Voltage regulators
- Buffering for guitar input and outputs
These two boards together give you a complete system. Both boards are both 10-pin SIP's and are 1.0" x 0.6" allowing both to be mounted up-right close together in tight spaces. The micro-usb connector allows you to plug in a USB cable even after the boards have been soldered or plugged into your setup. That way you can build your pedal and download new DSP algorithms at any time even after it's been built (you have to of course open your stompbox up to do this though).
Using these boards you could make a 4 knob pedal; one knob for volume/output level, three knobs for effects control (hook up to three pot inputs in DSP board), guitar input and effect output (hook up to companion board that already has the buffers and low-pass filters), expression input using the other analog input, true bypass, and battery connection (hook up to companion board since the 9 volts are divided to 4.5 volts using a switched-cap network). Current drain on the battery would be around 25 mA not counting current for your bypass LED.
