Author Topic: 'LIGHTWAH'  (Read 207088 times)
~arph
Re: 'PULSEWAH'
« Reply #80 on: March 11, 2011, 10:45:46 AM »
cool guys!... :icon_wink:
had lots of grief with my pc today....had to do full install...arghhhhhhhhhh..still tinkering. :icon_rolleyes:
try this: http://ninite.com/
Re: 'PULSEWAH'
« Reply #81 on: March 11, 2011, 10:54:16 AM »
looks good...too late though!..nevermind.... :P cheers though... :icon_cool:
i;m crossing over to win7..64bit. cubase 5/ reason / superior2.0  ezdrummer. ..great studio setup...lots to do!.. :icon_wink:
back soon.! :icon_twisted:
gnognofasciani
  • Contributor
  • Total likes: 0
  • Burn in hell you digital pedalboard!
Re: 'PULSEWAH'
« Reply #82 on: March 11, 2011, 11:41:42 AM »
Those are the files for the original version, PLEASE NOTE THAT THE LAYOUT IS CURRENTLY UNVERIFIED!
I won't be able to build it for some time, so use the files only if you are willing to test and verify it!
To use the rate led as status led simply connect one of the wires to your main bypass switch!
Hope you like it!
If anyone's interested I can post the buffered version too, but it'll take a while to fill all the values ;)
Search button is your friend
ronnie
Re: 'PULSEWAH'
« Reply #83 on: March 11, 2011, 01:15:38 PM »
is LDR1 just a 5mm led or is it a special optocoupler
Re: 'PULSEWAH'
« Reply #84 on: March 11, 2011, 01:18:04 PM »
@gnogno....nice work man, what prog did you use for that?....
@ronnie, ldr is a light dependant resistor.....
gnognofasciani
  • Contributor
  • Total likes: 0
Re: 'PULSEWAH'
« Reply #85 on: March 11, 2011, 02:13:29 PM »
Thanks! I used eagle it's the best ;)
Valoosj
Re: 'PULSEWAH'
« Reply #86 on: March 11, 2011, 02:44:50 PM »
Once you get used to it ... maybe
Diptrace has everything eagle has to offer and it's much more user friendly.
Quote from: frequencycentral
You squeezed it into a 1590A - you insane fool!  :icon_mrgreen:
Quote from: Scruffie
Well this... this is just silly... this can't fit in a 1590B... can it? And you're not even using SMD you mad man!
ronnie
Re: 'PULSEWAH'
« Reply #87 on: March 11, 2011, 03:17:18 PM »
Thanks Rob,
I have a few VTL5C3 photoresistors, will that work
or is it a different type,
ronnie
Re: 'PULSEWAH'
« Reply #88 on: March 11, 2011, 03:32:09 PM »
Hope you like it!
Thanks for the layout and pcb, is their anything that shows the part values for the layout
gnognofasciani
  • Contributor
  • Total likes: 0
Re: 'PULSEWAH'
« Reply #89 on: March 11, 2011, 03:48:16 PM »
I'll try to complete it tomorrow ;)
ronnie
Re: 'PULSEWAH'
« Reply #90 on: March 11, 2011, 04:15:55 PM »
Thanks man, I'm gonna build it this weekend, I'll keep you posted
on your layout, we;ll see if it all works,
Thanks for getting the part values together
gnognofasciani
  • Contributor
  • Total likes: 0
Re: 'PULSEWAH'
« Reply #91 on: March 11, 2011, 04:44:03 PM »
Updated files (2nd and 3rd images are the same, i just pointed out pcb dimensions)
Here's the partslist:
Partlist
Part        Value
R1          100k
R2          82k
R3          470k
R4          1,2M
R5          2k2
R6          3k3
R7          6k8
R8          100ohm
R9          1M
R10        1,2M
C1          1n
C2          4n7
C3          5p
C4          6n8
C5          2n2
C6          1u
C7          470u
C8          220u
C9          100n
C10         1u
D1          RATE LED       LED5MM
D2          LDR-LED        LED5MM
D4          1N4001
IC1         TL081P
IC2         LM555N
Q1          BC550
RATE        4k7 LIN
DEPTH       4k7 LIN
MANUAL      25k LIN
PULSE-TREM  SPST
AUTO-MANUAL SPDT
« Last Edit: March 11, 2011, 04:47:07 PM by gnognofasciani »
tasos
Re: 'PULSEWAH'
« Reply #92 on: March 11, 2011, 04:48:18 PM »
dead astronaut's scematic is going for the tl071 and 2n3904....what will the different parts offer?
gnognofasciani
  • Contributor
  • Total likes: 0
Re: 'PULSEWAH'
« Reply #93 on: March 11, 2011, 04:52:15 PM »
Nothing in particular... just the parts I have in stock! You can use tl071 and 2n3904 (just take a look at the pinout for the transistor, I think it's mirrored)
bluesman1218
  • Great Contributor!
  • Total likes: 0
  • All generalizations are false.
    • Taking you back to a simpler time... with music
Re: 'PULSEWAH'
« Reply #94 on: March 12, 2011, 10:19:48 AM »
Thanks for doing all the work, Gno! What part is used for the LDR? I have never used one before.
Thanks,
Steve
It's all about the tone!
Steve
POPA - Plain Old Power Attenuator AVAILABLE for PURCHASE soon!
Silvertone 1482 rebuilt - switchable Tweed, tube reverb, Baxandall + / Little Angel Chorus build, tons of Modded pedals
Re: 'PULSEWAH'
« Reply #96 on: March 13, 2011, 01:24:59 PM »
great gnogno...just noticed the protection diode too...great forgot about that!..good idea! :icon_rolleyes: :icon_mrgreen:
looks good to me,
so the buffered version, would cure the 'pulse mode volume drop then?..
@arph. if using a quad, there will be 2 opamps left over wont there?....could a simple phaser be incorporated into your design too?.....
like the phase45...again just thinking aloud!.
« Last Edit: March 13, 2011, 01:28:03 PM by deadastronaut »
Re: 'PULSEWAH'
« Reply #97 on: March 13, 2011, 01:43:05 PM »
Thanks Rob,
yep... i roll my own...led/ldr...not as posh as yours!.. :icon_wink:
bluesman1218
  • Total likes: 0
Re: 'PULSEWAH'
« Reply #98 on: March 13, 2011, 01:47:18 PM »
Steve
Re: 'PULSEWAH'
« Reply #99 on: March 13, 2011, 01:50:28 PM »
@steve like these!...
http://cgi.ebay.co.uk/5-x-Light-Dependent-Resistors-LDR-light-sensor-/300421550722?pt=UK_AudioElectronicsVideo_Video_TelevisionSetTopBoxes&hash=item45f2851282
Thanks, Rob. Anyone have a US source for these? I couldn't find them on Mouser or Digikey.
hi steve, probably at radioshack?....the usa version of our uk maplins..
they might call them photoresistors...on digikey or mouser..
