I guess nothing wrong with a quick rundown of parts that I can ID
The one mystery IC just needed a loop and a flashlight applied so I could see it.
Two boards, very elegantly arranged. Whole thing is top notch. I really wish the LEDs fit the logo better for aesthetics, but it is a pedal not a light show. Case is a custom clamshell design, the back and L/R sides come off, while the top and T/B sides hold all jacks and pots, which in turn hold the two PCBs. There is room for two 9V batteries in this config (I think) and it might inspire someone trying to fit an 18V creation into a standard box.
Top side has in and out 1/4" jacks plus 48vdc input. Top has a standard stomp switch, and 4 pots; gain, overdrive, distortion and tone (sort of).
All stainless, including the four stainless screws holding it together. Like I said, top notch, but at their price point you should expect that.
Inside are the two boards. One (the main one) with a few discreet parts and several micro board mount parts, I assume various resistors and caps. There are two 1/4w resistors, two diodes (germanium 1N I think, can't read, but the little orange-black in glass kind). A 330uf electrolytic and 3 ICs (op-amps?):
BB-OPA
2604AU
84VFX
The second board is held by the footswitch, and is connected to the first by a ribbon cable (pretty neat space saver). It has 8 LEDs in two rows of 4, two red and two yellow, which apparently are used for distortion. They fluctuate depending on the signal strength (guitar volume and OD setting). A third LED is a three-legger, it appears to show a dim light when plugged in and a stronger light when the switch is on. I like that approach too. This board has the mystery component. A flat potted box with 5 legs coming out. The wide flat kind, like on a power triode or something. And it has an IC:
BB-OPA
2604AU
89N67
That is it. It works well for me. The 48V inline brick supply is to my liking but it might be a pain with a full board. It has plenty of clean gain and sounds good on bass. The distortion I'm not really into but that is where the tone knob comes in; it appears to pull the rough high freqs out of the distortion, muddying it a little and making it a little more pleasing to my ears, but I prefer to use it just as an overdrive to pump up the amp input. I'm not a musician/technician but i did stay at a holiday inn express while playing one on TV. YMMV.
