I Think I Found the Problem
Started by texstrat, January 12, 2011, 05:21:11 PM
texstrat
Quote from: milosch on January 13, 2011, 09:11:52 AM
On the DC jack it appears that the tip is wired to ground.  Is that on purpose (negative voltage on tip) ?
This Fuzz Face clone is using PNP transistors and is (+) ground
twabelljr
I think the only voltage on the tip should be ac voltage from your guitar when you play. The tip is for audio signal no matter the polarity of the circuit. Right? With a cable plugged in to the input and output, do you measure dc voltage from tip to sleeve of the unplugged end of either cable?
Shine On !!!
Jhouse
Yeah. The tip is strictly for audio.
texstrat
Quote from: twabelljr on January 13, 2011, 02:05:51 PM
Grounding to the DC ground or jack?
Kinetic
I'd take the entire circuit out of the enclosure, so you can eliminate all possible shorts relating to the metal of the box.  Then re-test.
texstrat
Removed everything except the dc jack, its plastic, and still the same problem exist. Just so I understand, if a short exist, would it not make the battery warm/hot? I have dealt with a short during the build and the 9V got very warm. What else might cause the voltage to drop and then settle?
Govmnt_Lacky
Just a shot in the dark however...
I breadboarded a PNP fuzz recently and had ALL KINDS of problems with oscillation, low volume, wild voltages, etc.
Turns out.... I had tapped the input AND the output to the same row in the breadboard!  :icon_redface:
I never thought to look for this because the circuit KINDA worked.
Good Luck  ;D
texstrat
Quote from: Govmnt_Lacky on January 13, 2011, 03:46:06 PM
Good Luck  ;D
I about ready to call it quits on this and send it back to GGG. This has been a pain in the a$$ since the get-go. I can fix a tube amp, but I cannot run down the gremlins with this project.
runmikeyrun
Quote from: danielzink on January 13, 2011, 09:02:19 AM
Quote from: texstrat on January 12, 2011, 10:58:34 PM
Pulled the jack out and still the same issue. I have power to both sleeves 8.93V, but probing the input tip the voltage starts at 8.45 and drops to 8.00. I get nothing on the output tip back to the switch.
Someone correct me here - but sleeves are ground - no ?
I wouldn't think there should be any voltage on the sleeves.
Dan
Right, you should have continuity to ground with the sleeves, no continuity to 9V, and def no voltage on them!  Check your power wiring... do you have a multimeter that goes "beep" when you have continuity?  You should have no beep between 9V+ on the battery clip and the sleeves on your jacks.  if you have a beep you've got a short, or its wired wrong, maybe backwards.
Bassist for Foul Spirits
Instagram: @torcheffects
Dislikes: old women
Cardboard Tube Samurai
I'd suggest that anyone attempting to help debug this should go and read the other thread where several people have tried to nut it out
To clarify my previous post, I asked this question in the other thread but he's adamant that he has the DC jack wired correctly. Still looks wrong to me too
Also, have you tried replacing the transistors yet, just in case you happened to kill one when they were oriented incorrectly?
Jhouse
#32
QuoteTo clarify my previous post, I asked this question in the other thread but he's adamant that he has the DC jack wired correctly. Still looks wrong to me too
It's because his pedal is using PNP transistors and a positive ground.
Govmnt_Lacky
The ONLY thing that stands out to me would be to check and make sure your input jack is wired properly. It is easy to get the RING and the TIP solder points confused.
Jhouse
#34
If I get a chance, I'm going to throw one of these bad boys together tomorrow and see how they work. Texstrat's problem has really been bugging me lately.  :-\
QuoteThe ONLY thing that stands out to me would be to check and make sure your input jack is wired properly. It is easy to get the RING and the TIP solder points confused
But it passes signal when the pedal is bypassed. It couldn't do that if you had the jacks messed up, right?
texstrat
I do have an audible continuity tester and neg. probe on ground and touching pos. probe to neg. on battery and dc jack, I get a beep. Testing the lugs on both the input and output jacks I get no tone. That is checking with the effect on.
I checked to be sure that I wired the jacks correctly, sleeve, ring, tip and those are correct.
It plays in by pass, the LED lights up when the switch is pushed, I thought I had wired the switch wrong, but looking at some other DIY sites, it looks similar. And more importantly, I followed GGG layout per the instructions on his site........
Jhouse
#36
Swap out your transistors* and see if that makes a difference. Didn't you say that you had extra in the other thread?
twabelljr
QuoteGrounding to the DC ground or jack?
Grounding to the cable sleeve. Plug the cable in to the jack, then measure from the tip to the sleeve of the other end of the cable. The end that would plug into your guitar and/or amp.
QuoteBut it passes signal when the pedal is bypassed. It couldn't do that if you had the jacks messed up, right?
I was thinking the same thing earlier. The voltage (or whatever is wrong) must be getting there or happening when the effect is turned on. Good idea recommended to put two new transistors in. Simple enough test.
I see you live in VA texstrat, I live in MD. This is so intriguing I say bring it over and we can fix it! I am gonna print and study these pictures. Got recent pics of both sides of circuitboard and offboard wiring since you have been attempting repairs?
Shine On !!!
texstrat
Quote from: Jhouse on January 13, 2011, 05:31:36 PM
GGG set new components and I just put the new set in and no change.
texstrat
Quote from: twabelljr on January 13, 2011, 05:32:32 PM
I appreciate the offer and can meet you where ever.   :icon_smile:
