Author Topic: Spark Gap: Unusual 9V Hybrid Valve Overdrive  (Read 66857 times)
Re: Spark Gap: Unusual 9V Hybrid Valve Overdrive
« Reply #20 on: February 01, 2011, 11:30:38 PM »
   :icon_wink:
  Interesting application for a space charge device !
  Did you have to search for it or did you know what to look for ?
Govmnt_Lacky
Re: PCB files
« Reply #21 on: February 02, 2011, 08:56:16 AM »
I use Evatron enclosures, but since it's 60mm wide I *think* it would fit in a Hammond 1590N.
Are you using PLASTIC cases from Evatron?
for an amount of ‘up to and including my life.’
merlinb
Re: PCB files
« Reply #22 on: February 02, 2011, 03:55:04 PM »
No, they're aluminium.
Govmnt_Lacky
Re: PCB files
« Reply #23 on: February 02, 2011, 04:06:40 PM »
If its not too much trouble, could you post a link to the enclosure because I could only find  that size in plastic.
merlinb
Evatron enclosures
« Reply #24 on: February 02, 2011, 04:21:14 PM »
« Last Edit: February 02, 2011, 04:22:52 PM by merlinb »
benl560
« Reply #25 on: February 02, 2011, 04:25:13 PM »
merlins layout will fit in a 125b hammond without much room to spare.
i would have another one done to post, but i think smallbear forgot about me...
Govmnt_Lacky
« Reply #26 on: February 02, 2011, 04:43:19 PM »
I would hope so because the Evatron that merlin uses is smaller!  :o
Hammond 1590N1 (125B) = 121 x 66 x 40
Evatron EVA60 = 114 x 64 x 30
benl560
« Reply #27 on: February 02, 2011, 04:53:46 PM »
got me by 2 mils! so close, yet so far away...
i looked briefly for evatrons, but none of the sites i usually buy from sell them. are they nice as far as enclosures go? they appear to have a different "stance"
Joecool85
« Reply #28 on: February 02, 2011, 07:23:04 PM »
I'm still looking forward to a sound and/or video clip.  I gotta hear this thing!
Life is what you make it.
https://www.ssguitar.com
BadIdeas
« Reply #29 on: February 05, 2011, 11:33:44 PM »
Very intriguing. I don't really understand tubes, so forgive this possibly stupid question, but...
Are the current/voltage characteristics really a function of filament voltage or filament current?
Clearly the tube diode acts differently from the silicon and germanium diodes. I will have to try them some day. What is the filament voltage on this graph?
(From your post on my thread some time back)
How hard can it possibly be to put FRESH vegetables in a can? Seriously.
merlinb
« Reply #30 on: February 06, 2011, 03:53:21 PM »
Strictly it's filament power (temperature) that counts, so you can use voltage or current as the variable. However, "E" series valve have heaters designed for voltage drive -the rated current being approximate- so I stick to voltage measurement in such cases.
6.3V (the rated value). Here's what happens when you alter it. These curves only show what happens at less than 500uA anode current, but that's the region that matters in pedal design.
« Last Edit: February 06, 2011, 03:55:35 PM by merlinb »
BadIdeas
« Reply #31 on: February 06, 2011, 07:54:39 PM »
Looking again, I'm not sure I like your bypass. Don't you lose treble through the volume pot? Could you use a second BC337 between the output buffer's +input and the 10n cap or just put the existing one there? I don't have the means to cook one up right now, but what do you think? Maybe it's just fine, but it looks like a possible improvement.
benl560
« Reply #32 on: February 06, 2011, 10:34:04 PM »
hay merlin, are there any problems that you know of with your pcb layout? im not getting any voltage through pin 3 of transistor Q3.  ive checked everything like 5 times, no solder bridges, good joints, etc...
then i did one of those cardboard coca cola box layouts of up til the heaters and...
volla! voltage throughout.
either i got a bad diode or there's an error in that section of the pcb.
just wondered if you knew of an error..
merlinb
« Reply #33 on: February 07, 2011, 07:05:19 AM »
No, there is no loss. The output impedance of the "ON" transistor is extremely small.
Nope, it's the layout I used! One thing perhaps; the polarity of D2 is not marked (anode to ground), but that should be obvious from the schem.
« Last Edit: February 07, 2011, 07:09:21 AM by merlinb »
misterg
« Reply #34 on: February 07, 2011, 12:54:09 PM »
PCB worked for me.... (2nd build, not boxed up yet)
Sound clip of sorts
Here's some noises I recorded through the vero build. No tunes, just single note & chords:
First set clean, then I gradually increase the Fat control to max, back to clean, then increase the Mids control to max (Fat at min), clean again, then increase both together. I think it gives a fair representation of how my build sounds. I tried to be consistent from clip to clip -  Nothing was clipping except the pedal (Single coil neck pickup on a strat copy).
http://www.4shared.com/audio/JSxRgHCk/sg-ts.html
Andy
« Last Edit: February 07, 2011, 12:55:52 PM by misterg »
benl560
« Reply #35 on: February 07, 2011, 07:10:44 PM »
ok thanks guys!
there has to be a bad component on there somewhere. ive checked EVERYTHING like 7 times now. i mean, ive stared at this thing for hours now.
oh well. im just gonna make a new board, get some new components, and start again.
misterg
« Reply #36 on: February 08, 2011, 01:36:19 PM »
You've done THIS, right?
Post your readings & a high res, in-focus picture of the top & bottom of the board (taken with a CAMERA, not a f%&$??g telephone) and I'll have a look :)
I think the TL074 is somewhat static sensitive, so you might have zapped it if you didn't take precautions. Maybe try plugging a different one in if you're confident that everything else is OK. (You did socket it, didn't you??)
Andy
BadIdeas
« Reply #37 on: February 08, 2011, 03:16:51 PM »
OK, I get it now. Never mind me. I'm still figuring these things out. Great design.
Through Google Shopping search, I found the 6AL5 available from Triode Electronics, as well as a bunch of eBay listings. Where did you get yours?
benl560
« Reply #38 on: February 08, 2011, 04:29:08 PM »
yep did all of that.  i dont think its is the tl074(at least not yet) as there is NO voltage on any of the circuit past Q3, the bd435.
my power supply is a steady 9.48 volts
Q1
1, 8.87
2, 9.48
3, 0
D 1N4001
A, 0
C, 9.48
Z9V1
A, 0
C, 8.86
also, ive tried 2 different transistors for q3
i will post some pictures here in a couple hours.
benl560
« Reply #39 on: February 08, 2011, 04:36:29 PM »
 :icon_exclaim:
what an idiot!
i believe ive gotten my transistor in backwards.
this is unbelievable. i spent the past 2 days staring at this thing angrily and checking and checking.
today, maybe 3 minutes.
jeeze... well now i can see if the rest of this is right...
