Paul,
Oh I definitely made sure to check the right tab. BOTH tabs show continuity to ground. Is it possible that my DMM has a much higher sensitivity and the beeping is a false positive?
DMMs that have a continuity test (beep) function only require some small non-zero resistance to consider the circuit complete - 50 ohms on my Fluke DMM. That wouldn't make difference for you because the LM338 tab should measure off the scale (high) resistance to ground. The TDA7240 tab should measure zero resistance to ground.
So based on your description (both tabs being connected to ground), if you measure the resistance between the two tabs (on the LM338 and the TDA7240), you are getting zero resistance between them? If that's true, then I would expect your power supply to shut down (temporarily or permanently) as soon as you connect power to the board. If the amp is working when you connect power, then the only explanation I can think of is that your DMM is bad. What is the actual resistance measured between the tabs (disregarding the beeping)? Zero?
-Walt
Thanks for making me second guess my DMM. I don't think it's broken, but it would appear the threshold for continuity behaves funny.
For instance, the TDA7240 to ground beeps consistently and measures 0 resistance (it bounces around the .00-.06 range and back over and over) while the LM338 to ground beeps momentarily and then the resistance climps to infinity slowly to infinity. For some reason my DMM is slow on the uptake.
Also, the speaker connection to ground does the same thing--beeps briefly to indicate continuity, but then you can watch the resistance climb to .5K (that still seems low, though...doesn't it?).
I'm glad this seems to explain the mystery of continuity, but I'm still getting small shocks from the microphone when I use this amp with a PA, while others don't have the same effect.
Could it have something to do with my power supply? I have 19V 4A 3-pronged supply on which I soldered a new jack (to fit a regular DC pedal input). Should I try an insulated input jack?
I appreciate your help and patience with this build. I love this amp when it's not shocking me! Ha.
