Behringer DD400 no sound
Started by Archer18, February 16, 2011, 02:37:09 PM
Archer18
Hi, my friend just have me his Behringer delay to fix. The problem is is that there is no sound regardless whether the pedal is bypassed or not.
So what could be the problem?
Thanks,
Hides-His-Eyes
Does it power on? Look inside; is the PCB damaged?
Archer18
Yeah it does power on and the PCB doesn't look damaged.
Hides-His-Eyes
Bad news. Could be a fried IC. Not really sure what to tell you.
Archer18
Would that cause it to not work even when bypassed?
Thanks for you help aswell  :)
Hides-His-Eyes
Possibly, depending on the implementation (software mixing)
The op-amp could be fried too
in terms of pedal price to debugging difficulty (and repair difficulty of SMD parts) I wouldn't waste any more time on it
Quackzed
i'd check the moving parts first. the jacks for one can push/pull such that their legs will pull up and/or break the traces on the board they are attached to... thats my guess, or possibly a broken wire or cold solder joint somewhere?
