I'm just not seeing how it's capable of that with so few circuitry.Exactly what I thought.
But it does.
Signal grounded for simplicity, supplies are +/-5V. (This won't interface nice with some logic, but that can be fixed.)
Input V2 is a 0.5V peak sine wave. On the plot I multiply by 18 so it can be seen among the larger outputs: green line V(V2:+)*18
Bits A B C go up and down. I've offset a trice so they don't overlap.
The proof of our ADCs is a DAC: do we get back what we put in? The "V(BitC) + V(BitB)/2 + V(BitA)/4" is of course the function of a 3-bit binary DAC. Orange line.
The orange line "matches" the green line as good as possible with 3 bits, 8 steps. And there are no glitches at the transitions.
TL074, which (according to the datasheet) isn't happy driving loads less than 10k.?? Errors are near-zero for 2K load. I used 1K:56 cuz I'm too lazy for math, but (ummm) 2K and 112 or 2K2/123 is the same ratio and 112--123 is far less than the 230K divider.
big ratios are arbitrary, but they keep the thresholds near AGND, which I thought would be useful for the small signals coming from a passive guitar.In general, when doing decisions on small signals, you first bump them up to substantial level. Dwarfs offset errors, speeds switching response. Gain of 10 simple analog amplifier.
to avoid phase inversion problems.Simulated LF411 (granddaddy of TL07x) showed that effect. Turn it down a trace.
At 3 bits you probably DO have a compromise between no-output below -18dB, and whatever overload artifacts your chip has. You can clamp, you can use another chip.... leave that for later.
It might actually be a ratio of the two ratios that mattersOh, surely the two ratios must track. I suspect numbers like 2:1 and 1.5:1 work for large inputs, but I too am too lazy to work the numbers.
