Hey guys,
I've undertaken a project to get me into PIC programming, microcontrollers and programming in general, since I've always avoided it like the plague. After nearly failing a microcontrollers class this last semester I've put my foot downand decided to get some learnin' done. I thought I would post my work from the last few days, I've been designing and coding an LFO with variable uptime/downtime potentiometer controls. I haven't prototyped but I have simulated it with code and it works great. I'll be prototyping tomorrow after I code squarewave mode into it.
If anyone is wondering, I'm using the Proteus suite of design tools and CCS C for coding/compiling. Proteus allows me to spice sim hardware and code within a PIC and a simultaneously, so that is my prototyping thus far.
The schematic:
The code:
#include "18f2525.h"
#use delay(internal)
long value, an1, an2, math1, math2;
//Matt Bechberger May 4th 2011
//Functioning LFO from 62Hz to 0.25Hz, triangle wave, variable uptime/downtime
//not to be saved over!
void main()
setup_adc( ADC_CLOCK_INTERNAL); //set up the ADC to use internal clock speeds
setup_adc_ports( ALL_ANALOG); //set all ADC ports to analog inputs
set_adc_channel(0); //switch adc to chan 0
value = 0;
an2 = an1 = 0;
upcount:
math2 = read_adc(); //read uptime value from chan 0
if(math2 == 0)
{math2 = 1;}
an2 = math2 * 30;
while (value<=255)
output_c(value); // output count val to port C
value++; // increment count value
delay_us(an2); //delay for uptime delay time
if(value == 255) // when it finishes goto down count
{goto downcount;} //jump to down counting code
downcount:
set_adc_channel(1); //switch adc to chan 1
math1 = read_adc(); //read uptime value from chan 1
if(math1 == 0)
{math1 = 1;}
an1 = math1 * 30;
while(value<=255)
output_c(value); //output value to port C
value--; //decrement value
delay_us(an1); //delay for downtime delay time
if (value == 0)
{goto upcount;}
The result is a triangle output with perfectly variable uptime/downtime, and max and minimum frequencies of 62Hz and 0.25Hz respectively. I'll have to see how well it performs in real life.
Please don't critique it too hard, I've been doing PIC programming for about two days, and C for about a week. Before that, I've scraped a couple languages in high school, and the aforementioned microcontrollers class was assembly. It nearly killed me.
One thing I am wondering though, does anyone know if there is a way to make a pseudo-sine wave out of a triangle/square wave? 3rd order filter on a square wave? Waveshape tables? Algorithm? I'd be interested what the community has come up as a novel way to do so. In the case like this, where it is a control signal, purity of form is not required since it is not an audible signal, and the imperfections won't be noticeable.
Anyway, I'd be interested in hearing what anyone might have to say, and some discussion on techniques for accomplishing D/A, etc.
