Author Topic: Question about LEDs  (Read 3879 times)
Blatant
Question about LEDs
« on: May 08, 2011, 09:45:41 AM »
Hey guys I recently bought a bulk pack of mixed LEDs online. I've no idea about the stats of them, so using a multimeter, is there any way to tell what sort of resistors I will need for a 9v source?
I get the online calculators, but you need to know amperage etc.
cheers
arma61
Re: Question about LEDs
« Reply #1 on: May 08, 2011, 09:53:26 AM »
an easy way it this
a pot connected this way, when you find the LED intensity you want misure the pot value and add the res value, that's your LED's resistor.
         ~200R         10k lin         LED
+9V----/\/\/\--------/\/\/\/\--------  -!>|----   -9
                           |_____|
Ciao
"it's a matter of objectives. If you don't know where you want to go, any direction is about as good as any other." R.G. Keen
Blatant
« Reply #2 on: May 08, 2011, 06:49:02 PM »
cool, why do you need the 200r in front?
is there a way to test its maximum before blowing?
cheers
« Reply #3 on: May 08, 2011, 09:28:37 PM »
cheers
if the 200r wasnt there , when you turned the pot fully it would blow it...you must have a resistor on any led...
try a 4.7k resistor on its own with the led..and work your way down to 200r......and you'll see the difference in 'brightness as the resistance changes... ;)
