You're welcome! :3
Also, if you want a bit more of gain, you can try using a Darlington or even a Mosfet in place of the output transistor.
For more compression, you could try a germanium or even a schottky diode instead of the one from the original circuit. I'd also suggest you to change the 6k8 resistor for a trimpot, so you can bias the circuit correctly and match it to whatever power supply you happen to use. Maybe 25k is enough, but if you wanna be sure, use a 100k trimpot (and if you want to be precise, you can always use one of those multi-turn trimpots).
It's a really cool little circuit to mess around with.
