Author Topic: Second build refuses to work  (Read 4684 times)
Eak
« on: May 31, 2011, 03:53:51 PM »
I built my first boost a few days ago and it works great. when I was building it I decided to make my own layout to see how well I could read a schematic. everything worked great
Built my second one today and it when I switch it on I get a lot of hiss and a very very low signal. The pot does nothing.
The transistor is oriented correctly, everything is grounded, the battery is fresh, I re-traced the circuit and everything is where it should be.
What else could my problem be?
Thanks for any help
Govmnt_Lacky
Re: Second build refuses to work
« Reply #1 on: May 31, 2011, 03:59:46 PM »
for an amount of ‘up to and including my life.’
aron
« Reply #2 on: May 31, 2011, 04:08:22 PM »
It you get a lot of hiss - usually that means the circuit is amplifying a lot. If you hear hardly anything, then that indicates some sort of problem with the guitar signal reaching the input of the circuit - at least the transistor. If the pot does nothing, then that usually indicates a short and possibly the reason why the large amount of hiss.
It's probably a short somewhere.
Eak
« Reply #3 on: June 02, 2011, 10:29:43 PM »
I guess I misspoke when I said "A lot of hiss" There's some hiss, but no more than normal.
I retraced the circuit and every looks perfect, exactly like my other build too.
aron
« Reply #4 on: June 02, 2011, 11:01:42 PM »
If you have a working build, compare the voltages on the pins of the transistors. There might be a bad solder joint too so use your meter to check if you have good connections between the board.
