Hi all.
Just completed this build. To me, it sounds great. It does all the Gilmour The Wall stuff (that's what got me interested), and some jet flanging.
The layout is perfect, worked on the first go.
Thanks Thomeeque for the great work. It's very compact. Indeed I recomend double-checking every step as you do, since the board is so populated it's difficult to insert/remove components later.
Since i've built this with components already on hands, I had to do some modifications. One of them is substitute the two series 33uF LFO caps for one 47uF and one 22uF. Don't know if it makes any difference on the shape of the waveform or other aspect, but works well.
Later I will post pictures and some sound samples.
Tiago
