Author Topic: Deluxe Micro Man  (Read 27399 times)
rustypinto
Re: Deluxe Micro Man
« Reply #20 on: August 02, 2011, 12:43:07 PM »
I believe
2 x MN3008 = 1 x MN3005
Correct.
Pinto,
Can I assume that you used the MN3005s from Steve at Smallbear? The ones that are ACTUALLY 3008's  ;D
Seeing as you have 4 of them in your lovely circuit above  ;)
Yes, i used the same "2K fakes" that Steve is selling here (which is a great price IMO):
http://www.smallbearelec.com/Detail.bok?no=247
ivanmarch
« Reply #21 on: August 05, 2011, 06:27:14 PM »
 :D
very nice!!!!
we appreciate your hard work!
thanks for sharing!
ivan.
Brymus
  • Total likes: 1
  • Bryan G. - Somewhere in the Mohave Desert USA
« Reply #22 on: August 06, 2011, 04:26:19 PM »
It says pair in Steve's description.
Are you getting two ICs for the 15.95 ?
Or is that because they are two ICs in one ?
(does it cost 32$ or 64$ to get all four IC's?)
Govmnt_Lacky
« Reply #23 on: August 06, 2011, 05:06:03 PM »
They way I read it... you get 2 of the IC fakes for $15.95
So you get all four for $32
for an amount of ‘up to and including my life.’
njkmonty
« Reply #24 on: September 16, 2011, 08:07:23 AM »
« Last Edit: September 16, 2011, 08:12:07 AM by njkmonty »
Govmnt_Lacky
« Reply #25 on: September 16, 2011, 08:11:22 AM »
You need to link the picture from a hosting site.
Try aron's, or dropbox, imageshack, etc.
njkmonty
« Reply #26 on: September 16, 2011, 08:12:51 AM »
i never new how to do it!!!!
was it url or img ???
because i did both?
« Reply #27 on: September 16, 2011, 08:35:35 AM »
Missed this one when it first came up.  Very nice work indeed.
Take note, kids!  SIPs are a wonderful thing and can make for delightfully compact footprints and easier layout.  make sure you have some on hand, just to inspire your thinking.
Govmnt_Lacky
« Reply #28 on: September 16, 2011, 08:46:05 AM »
njkmonty
Govmnt_Lacky
« Reply #30 on: September 16, 2011, 09:07:09 AM »
http://www.andonelect.com/secure/ImagesClientUpload/sips%202.jpg
I know what those are however, I believe that Mark was referring to these:
http://cdn1.iofferphoto.com/img/item/198/883/142/S6eZ.jpg
SIP = Single Inline Packaging
My  ??? comment was because I did not know how the comment related to this thread.
rustypinto
« Reply #31 on: September 16, 2011, 10:41:46 AM »
http://i999.photobucket.com/albums/af111/njkmonty/IMG_0575.jpg
Looks good!
Because all the op-amps in the micro man are SIPs.
***A note to all ***
R18/R22 (which are specified as 33k/33k) seems to make this muddier than usual. The original DMM values were 24k/51k, which you can certainly use. These are meant to kill off a little bit of the signal coming out of the compressor and reduce the clipping (notorious in DMM's). You can also omit R22, and make R18 15k-16k to maintain the filter's corner frequency. This will result in a little less muddiness, and slightly more clipping. You can attempt to compensate this by introducing more attenuation with the inner stage BBD op-amps (IC6A/IC8B).
Govmnt_Lacky
« Reply #32 on: September 16, 2011, 11:05:58 AM »
@njkmonty
That looks like a pretty good etch. Definitely go over it with an exacto knife as it looks like some of the traces are pretty close  :icon_eek:
@ rustypinto
Thanks for the clarification. I should have been able to put that together!!  :icon_redface:
« Reply #33 on: September 16, 2011, 12:55:03 PM »
Pinto,
I was kinda wondering why I say four MN3005s yet the graphics said 500msec.  My first thought was "What the hell is he clocking those suckers at?  And why doesn't he opt for more delay?"
Knowing that there is actually 8192 stages under the hood clears things up.
Don't sweat the SIP thing GL.  With the markings on the side and not the top, folks don't necessarily recognize them immediately from their hairline!  :icon_wink:
« Last Edit: September 16, 2011, 01:00:29 PM by Mark Hammer »
njkmonty
« Reply #34 on: September 16, 2011, 06:05:18 PM »
apart from opamps etc
what other  components do you suggest i  socket?
eg i noticed you mention r18, r22, i havent fully sat down and gone through everything,
but i usually like to high lite first the components which may need tweaking prior to install!
most parts im using are from smallbear , would like to avoid resoldering at a later date!
njkmonty
« Reply #35 on: September 17, 2011, 07:43:08 AM »
hers some more work in progress, any recommendations for extra component sockets for component tweaking?
rustypinto
« Reply #36 on: September 18, 2011, 05:32:25 PM »
i think what you have there is good. I didn't really anticipate sockets due to the density of the design, so i'm hoping some of the passive components will still fit with them installed. You'll just have to fiddle with them a bit, especially around the BBD sockets.
njkmonty
« Reply #37 on: September 18, 2011, 06:28:55 PM »
 i socketed the inline  ics, just in case i screwed up putting them in the wrong way or something!
socketed transistor aswell, and only the 2 x 33k resistors  (r18 and r22)
i also realised its pretty tight when using boxed 1uf non electros too!!  all 13 of them,
here is another progress pic, hopefully encourages other noobs!, apart from your biasing notes, i dont have an oscilloscope , so i might request a few tips before im done, !
one, other thing, after ready back through my post i noticed it may appear that ive tried to blotch out  young pedals info etc, this was totally unintentional, , that was a bad area in etch , so i coloured in with sharpie, since it was ground area!So non disrespect intened!!! ;)
also , only little things, but i used peel n press blue stuff, and i dont know why i didn't earlier, but this was my first transfer that  it did  on a pure flat surface,(was just doing it on the ironing board before!)  ie flat chopping board. Its amazing how many obvious things get forgotten, unless someone spells them out!
« Last Edit: September 18, 2011, 06:38:32 PM by njkmonty »
njkmonty
« Reply #38 on: September 19, 2011, 01:59:39 AM »
ok, populated board
clean signal works
led works
15v coming through
correct power going to all ics
guitar signal coming through when effect on,
all pots appear to work
hear different effects/ squeal (light pitch coming through when adjusting pots)
tried different combinations of trim adjustments, but  to not much avail
 can this be  biased/ tuned by ear?  or close to it until i get a oscilloscope?
any suggestions?
jbgron
« Reply #39 on: September 19, 2011, 02:05:32 AM »
You can get it to work by ear.  I found the first trimmer closest to the 3PDT is extremely sensitive and it took some very fine adjustment to get it working.  For proper adjustment and fine tuning you really need an oscilloscope.
