Author Topic: Introducing the "One Chip Chorus"!  (Read 148074 times)
  • Total likes: 130
  • Virtue signalling keyboard warrior since 2020.
    • frequencycentral
Re: Introducing the "One Chip Chorus"!
« Reply #100 on: September 18, 2011, 07:36:01 AM »
reminds me of my old boss dimension d!
This tiny circuit sounds like a Dimension D? Long live DIY!
pinkjimiphoton
« Reply #101 on: September 18, 2011, 12:01:23 PM »
yah, it's really subtle without a lot of modulation on chords, but is very noticeable on single note stuff.
and if ya stack the pt2399's up, you get a really nice "doubler" effect that's alot like the old "boston" sound.
stack up 5 or more, and it becomes a distinct slapback with modulation that sounds remarkably like a short tape echo.
really really nice box...
and the vero layout is VERIFIED...or is that VERO fied?
listen loud. blaze one first:
https://drive.google.com/open?id=0BzMJxNNgY3_yc0JNd0VqdmNIWEk
I stand for Truth, Justice, and the American Way. @#$% TRUMP! YOU ARE EITHER ANTI FASCIST, OR YOU ARE ONE. #BLM
#FuzzyGoodness
« Reply #102 on: September 18, 2011, 12:05:02 PM »
hi jimi:
cool, what is it like level wise compared to bypass signal, is there a noticable jump or slump?......i mean would you recommend the mix/volume/blend mod?..
been pondering on this today..
pinkjimiphoton
« Reply #103 on: September 18, 2011, 12:13:57 PM »
don't know yet, i haven't boxed it yet with bypass...today or tomorrow rob.
#FuzzyGoodness
Pigyboy
« Reply #104 on: September 18, 2011, 03:16:02 PM »
I have a board of Scruffies layout here and want to build this now I have some new PT2399's.
How are you guys stacking the PT2399's? First I have heard of doing this.  Can you stack them on Rick's Little Angel?
And you'll have to admit, I'll be rich as shit
I'll just sit and grin, the money will roll right in....
                                                            - FANG
pinkjimiphoton
« Reply #105 on: September 18, 2011, 09:25:07 PM »
i'd imagine you could stack 'em on anything that uses them. with delay chips i believe it doubles the delay time. all i did was stick one on top of the other so the pins all lined up just to check it out. if i had kept it, would have just quickly soldered them one on top of the other. 2 chips gave enough delay to sound like a double, 3-5 chips sounded almost like a really quick unity slap echo...
for vst guys, it sounded like latency....lol
#FuzzyGoodness
Taylor
  • Total likes: 68
  • The clean energy source of the future.
« Reply #106 on: September 18, 2011, 11:36:16 PM »
Why not just increase the 1k between pins 4 and 6?
anchovie
« Reply #107 on: September 19, 2011, 01:47:40 AM »
Thanks for doing this!
« Reply #108 on: September 19, 2011, 06:03:46 AM »
@taylor, so a pot between 4-6 would give a delay too?...
Taylor
  • Total likes: 68
« Reply #109 on: September 19, 2011, 06:21:10 AM »
Well, I haven't built this, but I would assume so based on the way the chip works in normal apps. The only thing is that the filtering is not designed for longer times so (without simulating it, just guessing) I'd expect it to get a little nasty as you extended the delay time, with less lowpass filtering than in something like the Echo Base.
« Reply #110 on: September 19, 2011, 06:25:51 AM »
cheers, i'll have to bread it and try a few things out. thanks.
pinkjimiphoton
« Reply #111 on: September 19, 2011, 12:14:47 PM »
i'm a newb, dude, i didn't know you could do that!! ;)  my pampers still have fuzzfaces on 'em, ya know? ;)
#FuzzyGoodness
pinkjimiphoton
« Reply #112 on: September 19, 2011, 12:16:39 PM »
my pleasure, thanks for sharing such a very groovy circuit!! i like it so much, it's going on my pedalboard today bro.
so...add the tag to your vero....VERIFIED!!
thinking about building a couple more and messing with them a little...doubling the delay time makes a really nice doubling effect! ;)
#FuzzyGoodness
pinkjimiphoton
« Reply #113 on: September 21, 2011, 04:12:49 PM »
i boxed it up, there isn't really a volume drop when engaged i don't think...i think it's just the psychoaccoustic phenomenon of it sounding so good, yet so subtle.
i haven't tried it into a big amp yet, just my old pignose 3060, it sounds great there...really organic. almost TOO subtle..more noticeable on single notes than chords.
#FuzzyGoodness
rhcp_schipper
« Reply #114 on: September 23, 2011, 08:10:07 AM »
Hello you guys,
Together with Chris from El Musico Loco I'm working on a One Chip Chorus. Chris made the pcb for me, and I will try and make it work. That last thing isn't happening yet.
I put on all of the components on the board, and hooked all the others things up like the  in and output etc.
So when I power on the one chip chorus, i have a bypass sound, but when it's engaged I only hear some hiss that slightly chances when I play some chords!
Chris said to post my problem on here because you guys could probably help me out here.
Some pics of my board.
Top:
Bottom:
Thanks,
Cheers,
Tim
anchovie
« Reply #115 on: September 23, 2011, 08:57:13 AM »
Voltage measurements for the IC pins, please!
rhcp_schipper
« Reply #116 on: September 23, 2011, 08:58:53 AM »
Sorry, I fairly new here. Can you explain how to? Thank you.
Pigyboy
« Reply #117 on: September 23, 2011, 09:00:15 AM »
Take readings from each pin to ground and post them up  :icon_wink:
                                                            - FANG
rhcp_schipper
« Reply #118 on: September 23, 2011, 09:24:08 AM »
Chris, will do that! Thanks for the info!
Pigyboy
« Reply #119 on: September 23, 2011, 10:10:56 AM »
Hey Tim,
Can you post pics of the rest of your off board wiring along with the voltages?  Everything looks good on the board to me...
                                                            - FANG
