Author Topic: Neutron filter on 12V?  (Read 1070 times)
photon
« on: August 04, 2011, 01:05:15 PM »
I was wondering if the Neutron will run on +/-12 volts. I have a regulated bi-polar 12v supply and it would be nice if I could use it directly.
Re: Neutron filter on 12V?
« Reply #1 on: August 04, 2011, 01:28:46 PM »
As far as I can tell it should work fine, just make sure your components are rated for at least 12 volts.
« Reply #2 on: August 04, 2011, 01:48:16 PM »
You may have to fritter around with it to get it to sweep properly in the downward direction.  I can't see any issues with upward sweep, but the down sweep  presumes a starting point, which in turn presumes something about what voltage/current to feed the LED in the optoisolator so that it "begins" from the optimum starting point.
