Author Topic: LPB-1 & F.F. in one enclosure  (Read 1216 times)
Clubman35
« on: August 10, 2011, 08:20:39 PM »
I want to put a LPB-1 & a FF in one enclosure and had a few questions. Does each circuit need it's own 9v battery (seems that it would)? If so, I'm guessing that they can't share a common ground, correct? And, since the second effect will have no input jack and receive it's input from the first footswitch, how would you turn the battery off to the second pedal since removing the plug from the input jack will have no effect on the second circuit? Hope this makes sense...... I did a search for this using, "Two effects in one enclosure" and didn't find what I was looking for. Thanks.
Govmnt_Lacky
Re: LPB-1 & F.F. in one enclosure
« Reply #1 on: August 10, 2011, 08:35:26 PM »
I don't think BOTH of these circuits draw enough current to merit a second 9V battery. You can probably get by with one battery for both.
Good Luck  ;D
EDIT: I love Google  ;)
http://www.generalguitargadgets.com/pdf/two_in_one_wiring.pdf?phpMyAdmin=78482479fd7e7fc3768044a841b3e85a
BTW: Your FF AND LPB will need to be Negative ground if you want to put them in the same box.
« Last Edit: August 10, 2011, 08:45:23 PM by Govmnt_Lacky »
for an amount of ‘up to and including my life.’
Clubman35
« Reply #2 on: August 10, 2011, 08:44:04 PM »
Thanks for your help.  :)
