Author Topic: Boss SD-1 LED Diode concern  (Read 12404 times)
Zombie_Crush
« on: August 19, 2011, 07:15:19 AM »
Hi
Just Modded my SD-1 with a standard red brightness 3mm LED in position D4. Have check orientation which appears to be correct - and the pedal sounds a little louder.
Should the LED light up in this position? Have previously modded the clipping diodes to LED's in my DS-1 and they do.
thanks for your help
phector2004
Re: Boss SD-1 LED Diode concern
« Reply #1 on: August 22, 2011, 02:42:55 PM »
I think the LED has a higher forward voltage than whatever diode was in there before (1N914/1N4148 probably), meaning it'll cut the more extreme parts of the signal passing through, meaning a louder output.
The LED's should light up when the signal is getting clipped
FYI: You'll get a lot more responses in the "building a stompbox" section  ;)
