Author Topic: Is there a circuit simulation software with actual audio input/output ability?  (Read 7107 times)
jimosity
Basically, what I'm wondering is if there's a software where I can take say a clean guitar signal, use it as a loop - have it be used as the input to a circuit, then hear the output of the loop at the same time, then move/change parts around to HEAR the changes in real time?
Sorry if this is a dumb question.
Jim Rodgers
jim@americanhc.com
CynicalMan
Yep,
Seriously, any circuit simulator is going to be too complex to do in in realtime. You simply cannot have a simulator that's accurate enough to simulate most circuits and fast enough to have realtime output. LTSpice has a very slow wave in/out, but that's as good as you're going to get.
toneman
Linear's PSpice can create waveforms that U can hear.
MarkusW did it with the RingStinger, I think(?)
He created modulation waveforms and fundamental for the ring modulator.
I'm sure there's someone else that knows how to get "sound" out of PSpice(?)
Not me, though   :icon_eek:
afn
 8)
diydave
With Ltspice you can feed your circuit a wav-file of what you've recorded.
The output is also wav.
The user-manual explains how it's done. Quite simple.
Done it a few times, with interesting results.
Cjuried
This might be of interest... http://www.livespice.org/ I am starting to dig into this a bit further. Has anyone found other options? Thanks!
Chris Juried
Audio Engineering Society (AES) Member
http://www.JuriedEngineering.com (Juried Engineering, LLC.)
http://www.TubeEquipment.com (Tube Equipment Corporation)
http://www.Historyofrecording.com (History of Recording)
