Author Topic: Equinox: Easy PT2399 Reverb  (Read 183463 times)
merlinb
Re: Equinox: Easy PT2399 Reverb
« Reply #140 on: February 28, 2012, 01:50:21 PM »
some photos, but still not working though..
Hang on... it looks like you might have C28 backwards. That could be the cause of the hot 7805...
mr_deadmaxxx
« Reply #141 on: March 01, 2012, 10:01:47 AM »
looks more like photo-resist
yup, photo resist. I used pre-sensitized PCB's.
Holy cow how come I didn't see that?!? :icon_eek: :icon_eek: :icon_eek:
merlinb
« Reply #142 on: March 01, 2012, 10:35:29 AM »
Basic law of electronics. It doesn't matter how many times you check the board, you always have to check it one more time to find the last error.
mr_deadmaxxx
« Reply #143 on: March 01, 2012, 10:53:54 AM »
I always look at the solder side.. ;D
« Reply #144 on: March 01, 2012, 11:37:34 AM »
I brought my Equinox (and several tubs full of other pedals) to a jam/rehearsal last night.  It was the first time I'd ever heard it at anything above conversation level.  Sounded great!  Very pleased.
« Reply #145 on: March 01, 2012, 10:41:36 PM »
I can't wait to make this one. Definitely with a momentary foot switch:
Mark Hammer: Note that, since it comes with "tails", one could productively use a momentary stompswitch for the on-board switching.  That would let the user effectively "punch in" for a phrase, then punch out, letting the reverb decay in its own time.
I was thinking of adding a tap tempo mod, what do you think?  ;)
« Last Edit: March 01, 2012, 10:43:07 PM by garcho »
« Reply #146 on: March 02, 2012, 09:23:30 AM »
Not to rain on your parade, but I don't know that tap tempo will have easily discernible effects on a simulated reverb.  After all, the point of reverb is to make the repeats rather indistinguishable from each other.
merlinb
« Reply #147 on: March 02, 2012, 11:36:31 AM »
I hope that was dry humour, Mark...
« Reply #148 on: March 02, 2012, 01:36:58 PM »
That's my fault for assuming sarcasm can come across on a text forum  :icon_redface:    Couldn't help but laugh at the idea of tapping in a tempo for reverb i.e. 100,000 bpm
« Reply #149 on: March 02, 2012, 04:16:05 PM »
Okay, I get it now.  *I* was the one who was out of the loop.  :icon_rolleyes:
served
« Reply #150 on: April 16, 2012, 02:11:01 PM »
How does it work if I would like to use Hall and Pathroom Reverb types?
Would this be the circuit to build?
John Lyons
« Reply #151 on: May 22, 2012, 09:47:21 AM »
Fired this up late last night. Sounds great! Now to play with some feedback
and filtering. Thanks Merlin!
Basic Audio Pedals
www.basicaudio.net/
haveyouseenhim
« Reply #152 on: July 30, 2012, 08:06:43 AM »
Ahhh. this is such a nice sounding pedal, but i cant get mine to work. theres a short somewhere and i cant find it. i just decided to etch a new board and start over. when i was cutting the copper clad board to size, the box cutter i was using slipped onto the speed square and cut the tip of my finger OFF.  this project has been hell (through no fault of the designer) .
sounds great merlin. cant wait to finish it.
edit:  does anyone have any spare pcbs?
http://www.youtube.com/haveyouseenhim89
I'm sorry sir, we only have the regular ohms.
brv
« Reply #153 on: November 26, 2012, 01:00:16 PM »
Hello everyone!
I've recently built my copy of Equinox Reverb. Audio processing seems to work fine, except that it's quite noisy (my idea is to put it in one box with Echo Base, which also uses a PT2399 and doesn't produce any noise). The noise stays the same no matter if the reverb is on or off. Moreover I can't really hear the difference between "Low cut" on and off. I'm really out of ideas - after spending a lot of time examining the PCB, I can't find any shorts etc. Help!
Here are the pictures of my build:
http://imageshack.us/a/img197/9584/dsc00587jy.jpg
http://imageshack.us/a/img21/4291/dsc00585ux.jpg
Let me know if you need audio samples or a close up of any part...
« Last Edit: November 27, 2012, 03:09:07 AM by brv »
gtangas
« Reply #154 on: December 05, 2012, 11:20:19 AM »
hi
sorry about the noob question:
The pot P2 can be lin or log right?
« Reply #155 on: December 05, 2012, 12:19:13 PM »
Pots *can* always be one or the other (or antilog), it's just a matter of user-interface aesthetics. You know how some amps' volume knobs go from inaudible to crazy loud in 10 degrees turn? That's the issue with potentiometer taper.
Linear would be the choice here, if you have. Schemes usually make the need for audio, or log (or antilog) explicit (as in P1). Any will work fine, as long as the value (20k) is correct. Even if the value is higher, it will still 'work', but not as gracefully as the designer intended. In this case (with Merlin), I'd stick as close to the schematic as financially possible.
Here's a good quick read you should check out
welcome to the forum!
« Last Edit: December 05, 2012, 12:21:18 PM by garcho »
gtangas
« Reply #156 on: December 05, 2012, 06:14:33 PM »
I´ve been following the boom and the doubt of the pot came because the note was only on one off the pots
Here in Portugal I couldn´t find the pt2399… even it´s a ic called PT :)   but okay… long live ebay….
The other problem was the caps ND… after running from several shops I only found a polyester cap of 1,5uf but I think it’s okay
Thx for the welcome… I enjoy this stuff… I love play and I love to build my things…. I remember when I was a kid seeing my father drawing pcb with a edding pen :)
today´s more simple!!!
But yea! I´m starting from zero here! 100% noob!
Feedback of my first stompbox as soon my ic arrive from hong kong!
obrigado
Sérgio
brv
« Reply #157 on: December 06, 2012, 01:58:25 AM »
I've noticed a fact that might be important: the noise goes away when I turn down the level pot (what doesn't surprise me, but the same happens when the reverb is bypassed!). I also checked the circuit with PT's removed - of course there is no reverb, but I still can hear some minor noise which might be the cause (the reverb line amplifies it). I also tried to replace the TL072CN - no change. The wires used to connect the circuit to the amp ought to be ok, because I use them with many other stompboxes and never noticed any problems. Anyone willing to help?
merlinb
« Reply #158 on: December 06, 2012, 03:18:36 PM »
What kind of noise is it?
brv
« Reply #159 on: December 08, 2012, 12:46:43 PM »
It will be easier if I make a sample. Here's the link:
https://soundcloud.com/brv-2/reverb-noise
The sample consists of three parts - first one is the amp only (no noise at all), second - low level reverb and the third one - high level reverb. For me it sounds as if something was not grounded properly, but that's only a suggestion. Still the fact the noise almost (not entirely!) disappears when the Level know is down makes me wonder - this seems to be the same noise level (maybe a little higher) as with the PT's removed.
