With Merlin's permission and assistance, I made a PDF with all the files related to the Equinox. It has high-resolution images of the schematic, layout, and PCB transfer. The PCB transfer image is actual size. There's also a bill of materials included. The PDF is hosted here in the DIYStompboxes gallery - so it shouldn't disappear.Here's the download link: http://www.aronnelson.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=46248&g2_GALLERYSID=74c3a65f5fc52fdecfa64fec06407a15
Isn't the tracing software capable of exporting the board directly to the pdf?
Quick question: What's the point of transistor Q1? Am I right in thinking the output from the first opamp feeds into the input of the first PT? I just don't understand Q1.
Interesting. So it's simply the bypass on the circuit? I could just feed the output of the op-amp into the input of the PT?
Minro query (bit of a noob, sorry), would this require any modification for use as line level (synths etc)?
Quote from: Paradigm X on September 27, 2011, 12:29:28 PMMinro query (bit of a noob, sorry), would this require any modification for use as line level (synths etc)?The delay line will handle 2Vp-p signals as it is. If you want it to handle larger signals then you would need to reduce R11 and increase R19 proportionately.
Another quick question. R19 and C13 make up the feedback. When I don't connect these I just get two delays, as expected, when I connect the feedback though the circuit goes into crazy oscillation. This is expected also I guess but wonder if you know how to over come this? Get a the reverb to fade out gradually and not go mental!
