Hi, I'm attempting to make this build, but because I'm here and not in the "show completed projects" thread, it means I've made a mistake somewhere.
When I get everything plugged in except the input jack, I get random noises out of my amp that suggests things are probably working properly (similar to the noise when you plug in your guitar when the amp is on). As soon as I plug my guitar into the input jack, all sound cuts off from the amp except the usual low buzz as if nothing was plugged in.
I had a couple bad solder points that I fixed and made it as far as above. Now I am wondering if I wired my stereo input jack wrong. I picked up a strange one, the only one I could find in the area, and I don't understand the schematic for it on the back. I kind of guessed at it with the wiring, and I think I got it wrong.
Here is how I have it wired:
I google searched the description of the jack, and this seems to be the same thing:
http://www.guitarelectronics.com/product/JK31/9_Pin_14_Stereo_Jack_w_DPDT_Switch.htmlAny tips? If I got this wired right then it'll be a lot of debugging from here.
