Author Topic: Tufnel JRC386D IC  (Read 9526 times)
Rockitdog
Tufnel JRC386D IC
« on: October 21, 2011, 05:50:36 AM »
Hi there
I am looking at Beavisaudio's Tufnel schematic and it lists 2X JRC386D IC's.
Just done a search on Smallbear and my Local supplier (Mantech) and nothing come's up.
Is this the same Amp?
If not, what alternatives could I try?
http://www.mantech.co.za/ProductInfo.aspx?Item=35M4393
National - LM386N
Richard
Re: Tufnel JRC386D IC
« Reply #1 on: October 21, 2011, 06:01:31 AM »
yep they'll be ok..... ;)
they go to 11... ;D
http://www.youtube.com/user/100roberthenry
DavenPaget
« Reply #2 on: October 21, 2011, 07:07:43 AM »
Hi there
National - LM386N
Richard
Yup , any 386N can do , JRC386D will be quite hard to find .
Hiatus
Electron Tornado
« Reply #3 on: October 21, 2011, 08:52:04 AM »
Recommend using a 386N3. Notes will fade more smoothly than with a 386N1.
Thank you, Joe Anthony. (The godfather of rock and roll.)
Anyone can drill a hole. But, if you want it off center or misaligned I'm your man!
« Reply #4 on: October 21, 2011, 10:41:49 AM »
Hmmm, I dunno, it's such a fine line between genius and stupidity, innit?  :icon_wink:
The 386D can handle higher output levels without letting the magic blue smoke out, and is JRC's all-purpose version of the 386.  NatSem's version comes in 386-1, 386-3, and 386-4 flavours.  If you're aiming for credible loudness through 8-ohm speakers, the 4 is what you want, whereas the 1's are for more modest headphone levels into 16, 32 (or higher) ohm impedance headphones.  The D will do ya for any of those.  More rugged chip, certainly, though I don't know that it is absolutely necessary for a pedal.  It may sound a little different though.  I'm sure "Beavis" tried out different ones and liked these.  You don't have to, though.
jefe
« Reply #5 on: October 21, 2011, 11:11:38 AM »
Smallbear has 'em:
"Japan Radio Corp. version of the 386 for "Smokey" amps."
http://www.smallbearelec.com/Detail.bok?no=207
JRC386D is now known as NJM386D
edit: mouser might even have the NJM386D, not sure. Look up the datasheet for NJM386D, you'll see it's from "New Japan Radio Co" or something.
« Last Edit: October 21, 2011, 11:25:10 AM by jefe »
DavenPaget
« Reply #6 on: October 21, 2011, 12:41:25 PM »
He's not driving a 'phone , he's DRIVING A PEDAL !
It's like saying he's not driving a truck , he's driving a SCOOTER .
Though , i only have original JRC chips and none of natsemi's .
Hiatus
Rockitdog
« Reply #7 on: October 21, 2011, 01:01:18 PM »
they go to 11... ;D
 8)
Classic Tufnel.
Thanks a whole bunch everyone. Loads of options. Appreciated.
Rock on!
Rockitdog
« Reply #8 on: October 21, 2011, 01:09:32 PM »
Very handy to know.
Thanks  ;D
« Reply #9 on: October 21, 2011, 05:05:46 PM »
Understood.  Just clarifying the differences and what may or may not make them relevant to any given case.  This particular design wants a 386.  It doesn't need the ability to produce 1w into a speaker; it just needs to be a 386 of some sort.  Whether the JRC sounds better to your ears than the NatSem or some other form is up to you; same way it would be up to you whether a TL072 sounds better in your overdrive pedal than a TL082 or OP275 or CA3240 or JRC4558, etc.
electrichammer
« Reply #10 on: December 04, 2013, 08:59:07 AM »
Hi,
Ist it possible to replace the JRC386D IC with a Tube ?  ???
Thanks in advance
JustinFun
« Reply #11 on: December 04, 2013, 10:17:41 AM »
You could replace it with a tube *amp*  ;)
