I've done one.......fits in my 125B.
Only 1 jumper.
I'm no layout wiz.....
Designed in Eagle...
Woudent mind having it reviewed and revised. (I like to have all my off-board connections on the same side, but this one as them on 2 sides. Not a big deal I know!)
Not confirmed/built yet.
I want to mod the 2 switches (voices and dry signal) with pots to blend rather then just in or out.
I'm a jumper junkie.
I can't get rid of them. I can take a look at your layout, however.
You could probably do the pot thing, just replace the switches with pots wired as variable resistors. 100kA would be my recommendation, but I haven't tried that out. I'm not sure how useful the pots would be, but it's worth a try.
I think of doing a veroboard layout for a 1590BB enclosure.
What about a version that includes all the possibilities of the "modded" and the "stereo" version?
Can you post sound clips that demonstrate the mods?
regards, Immo
A vero layout would be great. I'm planning to build on vero, although I was going to try a 1590B.
I'm personally planning to build a modded stereo version with three switches. I just didn't put it up because I wanted to limit the number of schematics that I put up. The mods are pretty simple, and I figured people could mix and match at their leisure.
The first sound clip has the dry signal cut out at the very end. I can do clips of the other mods if you want, although that's the most unusual one.
