Would love to build a serious Mic Preamp. Suggestions?
Started by iandy4, November 04, 2011, 03:39:16 AM
iandy4
So I can't afford the n72 seventh circle kit yet but I'd like to try this hamptone design in the meantime.  I was hoping someone can give me advice on a few of the components in the schematic that are unclear to me.
http://www.tangible-technology.com/ipr/AE230/html/wk_6/hamptone_fet_scan.pdf
As for as the transformers go, for the mic preamp design that he shows, the schematic shows one 1:1 transformer and one 1:10 transformer.  What should the ohm's be for those and which manufacturer should I go with if I quality is the top priority?  I have some quality 10k:10k transformers from edcore and those standard xicon ones as well.  Would 10k:10k be good for the 1:1 transformer? What values for the 1:10 transformer?
Also in the schematic the resistors have either "Q" or "H" after there values.  What does that mean?
One electrolytic cap also says "LO ESR" What does that mean?
My Site:
artifus
#21
QuoteAlso in the schematic the resistors have either "Q" or "H" after there values.  What does that mean?
Q = 1/4W
H = 1/2W
1% metal film
QuoteOne electrolytic cap also says "LO ESR" What does that mean?
Low ESR Capacitors: Fact or Fiction?
http://www.jensen-transformers.com/apps_sc.html
http://www.lundahl.se/schematics.html
Johan
Quote from: iandy4 on November 08, 2011, 12:48:19 PM
I've had good experience with OEP A262A3E ( RS has them ) they are 1:6,3( or 1:3.15 or 1:12.6 depending on how you hook them up) and quite good at budget price( ~15euro). you can hook them up for 150 Ohm or 600 Ohm primary, so most mic's can get their optimum loading. don't forget the screening can...
J
DON'T PANIC
iandy4
My Site:
