Author Topic: Building the Uglyface PCB  (Read 31155 times)
Taylor
  • Total likes: 68
  • The clean energy source of the future.
« on: November 25, 2011, 05:59:47 PM »
Time for another "building" thread, this time for the Uglyface. Your build photos, questions, etc. can go here.
The top question I get for PCBs in general is usually how the pots should be oriented, so here's a picture (sorry for the bad photo quality):
http://musicpcb.com/wp-content/uploads/2011/11/uglyfacepots.jpg
Due to popular demand, this board has holes for standoffs if you're not into board-mounted pots.  :)
PereatMundus
Re: Building the Uglyface PCB
« Reply #1 on: November 26, 2011, 06:31:30 PM »
nice!!
I'll toss an order your way once I've sobered up!
now just ad skyripper and your selling all my favorite noicey stuffss.
*looking forward to future projects, seems your projects always tend to be right down my alley :)
electricteeth
« Reply #2 on: November 26, 2011, 06:41:14 PM »
I want one of these too! How can I get?
Taylor
  • Total likes: 68
« Reply #3 on: November 26, 2011, 07:31:09 PM »
There's a link in the first post to the board. I always try to not spam the forum with links because I know nobody likes that, so I don't want to put it in huge text or anything.
LaceSensor
« Reply #4 on: November 26, 2011, 07:40:29 PM »
Can an LFO be added to this?
Taylor
  • Total likes: 68
« Reply #5 on: November 26, 2011, 10:33:32 PM »
It can certainly be added in the way that people have added an LFO to the Uglyface before - but there's no LFO on the board. I could make a diagram to show how to do it if anybody was interested, but you would need to wire the extra parts on a little piece of perfboard.
karter2000
« Reply #6 on: November 27, 2011, 02:22:23 PM »
I'd be interested in that!  Been wanting to build an Uglyface with the LFO for some time.
Strategy
« Reply #7 on: November 28, 2011, 12:04:35 AM »
I recently (finally) figured out the technique of adding a voltage control input to pots using a vactrol. I have also thought about adding LFO to the uglyface (I built this on Soggybag's PCB from last year or so) but have plenty of LFO's and voltage sources available from other pedals or synth equip.
Taylor, in this circuit if one didn't want to 'build in' an LFO is there a best way to use the vactrol on board? I suppose that the issue then is that the envelope is always active at the same time as the external input unless a switching jack is used? ...or else just keeping envelope amount control on low when you want the external voltage or other voltage source to be active?
Strategy
Taylor
  • Total likes: 68
« Reply #8 on: November 28, 2011, 04:54:44 AM »
Hmm. If you had no switching and you just inject a CV into the LED side of the opto, then turning the sensitivity down (envelope off) would ground your CV. You'd probably better off switching between envelope or external CV. You may need to divide the input voltage to get it working within the right range for the opto to respond semi-linearly.
Strategy
« Reply #9 on: November 28, 2011, 01:19:36 PM »
Thanks I'll experiment with this. I guess an alternative would be to add the vactrol in parallel with the freq pot. That's $5 more expensive and then there's the matter of fitting the extra vactrol. Redundant, but might be a workaround - it will be some tricky labor to desolder what I built and install switching. Unless I build a second Uglyface!!  ;D
Linearity doesn't tend to be much of an issue with noisemakers for simple things like LFO's... I'm noticing that even with careful use of the vactrols it's pretty much "wild style" voltage control across the board...but still useful.
Strategy
LaceSensor
« Reply #10 on: November 28, 2011, 01:33:51 PM »
Ditto
Ben N
  • Total likes: 415
  • Ben N. - really! Now Israel, once Baltimore
« Reply #11 on: March 27, 2012, 06:17:48 AM »
If I put them in one box, can I tap the Gristleizer LFO to feed the Uglyface? If so, anything extra needed, besides a switch, such as a buffer?
Strategy
« Reply #12 on: March 27, 2012, 12:06:40 PM »
Yes a buffer would be a good idea. I tapped the Gristleizer LFO to a panel output, and when I patch it to something it decreases the effect/filter depth on the Gristleizer signal. I haven't built a buffer for it yet but ought to.
Strategy
angrykoko
« Reply #13 on: April 03, 2012, 12:02:40 PM »
Hey,
Ordering parts for this build and I'm going to just do pcb mounted pots on one of your boards Taylor.
I cant tell how wide it is though.. will it fit in a 1590B enclosure?
Or would a 125B be a better choice..
Thanks.
BTW:  I built an echo base from one of your boards.. that was the nicest board I've gotten to date!  Solder masked, through hole plating!  It was almost too easy to build.   :icon_biggrin:
Taylor
  • Total likes: 68
« Reply #14 on: April 03, 2012, 05:00:42 PM »
Yes, it will fit in a 1590b - as I recall it's 2 inches wide. But, of course, building in a smaller box makes things a bit trickier. Glad you liked the EB board!
wizardsofzen
Re: Building the Uglyface PCB - Envelope Control?
« Reply #15 on: April 06, 2012, 04:00:58 PM »
http://www.jiggawoo.eclipse.co.uk/guitarhq/Circuitsnippets/snippets.html - mentions envelope control, and then gives a really nice example... how would this be accomplished? i'm already putting 2 of these Uglys into some sort of enclosure.
Taylor
  • Total likes: 68
« Reply #16 on: April 06, 2012, 05:00:32 PM »
Envelope control is a part of the basic circuit. That's what the optocoupler is doing. If you don't have any envelope happening, you may have an issue with your opto.
wizardsofzen
« Reply #17 on: April 07, 2012, 08:43:17 AM »
thanks for that Taylor, haven't built them up yet, just ordering parts now
angrykoko
« Reply #18 on: April 17, 2012, 10:42:09 AM »
I was trying to recycle a 10K pot to build my uglyface.. long story short.. it broke.
I dont know the math to do this but I have a spare 100K pot, what value resistor would I need (across lug 1 & 3 from what I remember) to bring the 100K down to 10K?
Thanks for any help.
jwar
« Reply #19 on: April 17, 2012, 12:38:44 PM »
Quick Optocoupler question. I've never used one of these before and was curious about the orientation. I just want to double check that I'm reading the information correctly.
Does this look like the right orientation?
