Author Topic: Can I use a Mono jack as the input if I'm powering via adapter only (no battery)  (Read 4188 times)
vince37
I understand that the stereo jack is used to shutdown the power to preserve battery life but I never use batteries, so was wondering if I can just use a mono and a 9v DC socket?
Cheers.
CurtisWCole
Yes you can.
Curtis
Composers shouldn't think too much - it interferes with their plagiarism.
Howard Dietz
aron
Yep, everything should be fine.
vince37
WOW! rapid response!
Thanks.... I can use up all these mono jacks now :)
Cheers
chromesphere
Hi vince,
I often use 2 x mono's for builds, particularly if i have no intention of adding a battery or there's no room for a battery.  It's also a good idea to use mono's for tight builds like 1590a builds.  If you do add a stereo jack, you can always add the battery snap down the track as well.
All the best with your build!!
Paul
Pedal Parts Shop                Youtube
vince37
Hi chrome,
Yes, I'm a little more experienced now so I just wire everything with mono jacks.. as I never use batteries it makes things a lot easier and as you said, neater
Cheers
