A guy wrote to me, said that he ordered the surface-mount 13700 from me for this build because that's all I had. I Do stock the NJM13600 in DIP, which Merlin says should work; the Engineer's Thumb does not use the output Darlington stage, and that's the only diff between those chips. If anyone has used the 13600 successfully, pls advise. I have offered to send one to my customer, and will advise hoiw that works out.
Regards
SD
That would be me.
I missed the 13600 when I was going through the parts list
Added later, some of what I thought I wrote disappeared: I have actually etched the board and populated it with the components I have. I installed a socket for the 13600 chip that Steve has generously already sent me in the mail. I have plans to attach "legs" to the surface mounted chip to get it into the socket. I think that this will work since there are very few pins being used. I have checked out wires for the job and found a bunch of resistors that I have which seat perfectly in the Mill-Max socket I am using.
I should add that in looking at the pcb layout it looks like it could be modified to accept the surface mounted chip.
Note to Steve: It would be great if you could somehow incorporate a way to search for ICs by the number without the initial letters. I was looking to find LM13700 and only found the V13700M by scrolling through your entire inventory. All bets are that there will be no discernible difference, but I will report back. From looking at the pcb layout it looks like it would be possible to alter it to use the surface mount.
Geez... This was also lost in the original posting. It would be GREAT if there was a way to search for chips with just the numbers and not the initial letter designations (manufacturers???). (something like: **number*). An even better wish would be for a search that returned acceptable replacements!!!
I know that is too much to ask. Thanks for supplying the parts that you do. Small Bear is my Number One resource.
Oh, I should add that I have THREE shipments coming from Steve. The original, the 13600 he offered to send me, and a few parts to repair a Dunlop Wah that I forgot to add to the original order. I will be watching the mailbox eagerly!
