Onboard Solstice/Amp ApplicationI just wanted to share some information about using the Solstice as a onboard reverb for a practice amp. My application is a Murder One amp, but this would work with any other 9-12VDC amp such as a Smokey, Ruby, Noisy Cricket, etc.
The Murder One uses a 12VDC power supply, so I tapped the power from the amp's power switch to supply 12VDC to the Solstice. The op amp on the Solstice can handle more than 12V, and it sounds great at 12V. I'm using a 7805 regulator instead of the smaller 78L05, and it easily drops the voltage from 12 to 5V for the PT2399s without getting hot.
Since I'm not using the specified bypass switch for the Solstice, I simply jumpered the SPDT switch connections on the board. If I don't want reverb, I just turn P1 completely CCW and I get a clean signal. There's no need for a bypass switch when embedding the Solstice, and the main switch for the amp kills power to it when I switch the amp off.
I like to have P2 as an offboard pot instead of a trim pot, so the other thing I did was minimize the number of wires going to the offboard pots as shown in the drawing below. There's no need to run multiple ground wires to the pots.
Anyway, I hope this helps those who want to add reverb to their practice amps.
