For The Experts: Is Opamp I.C.M.R. and Bandwidth Related?
Started by Paul Marossy, May 09, 2012, 10:04:53 AM
Paul Marossy
Some of you may remember this thread about TL072 weirdness: http://www.diystompboxes.com/smfforum/index.php?topic=96006.0
The TL072 apparently has a quirk that "the input common-mode range does not extend all the way between the rails. If the common-mode voltage gets to within a couple of volts of the V- rail, the op-amp suffers phase reversal and the inputs swap their polarities. There may be really horrible clipping, where the output hits the bottom rail and then shoots up to hit the top one, or the stage may simply latch up until the power is turned off."
So this little 12V unity gain opamp splitter box thing I made to change the mono output of my old analog keyboard into a pair of signals to feed a digital FX unit was working consistently (the opamp didn't latch up or die), but I noticed after making a recording recently that it was clipping one of the signals. At first I thought that I simply had the recording level too high but then I noticed that I was sounding distorted all the time, and it got really bad unless I had the volume on the keyboard near zero, but then the more notes I played on the keyboard simultaneously, the worse the distortion got.
So I started thinking that I was having a new problem with my keyboard, but before I went down that road I double checked to see if my suspicion about it being the splitter box itself was correct. So I feed the thing with a clean sine wave from my signal generator and found something very interesting: both the outputs were squashed (like 1/3 the amplitude of the original) and one of the outputs was quite distorted and even less in amplitude. So I immediately thought that it was the opamp that was the cause of the problem. Then I decided to try a few different ones. The JRC4580 I tried first worked for a few seconds then latched up. Then I thought I should try using one of these wide bandwidth types just for kicks, so I popped an LF353 in there and looked at the waveforms – the outputs were just like the input! And it kept working and didn't die or latch up. Obviously that made me very happy because now it sounds great, like it should.
So all that to ask, is the input common-mode voltage and bandwidth somehow related? I'm having a little trouble understanding how bandwidth can be a factor when you're feeding a very simple unity gain circuit with a sine wave at a certain frequency and it's crumpling under "the pressure".
Paul Marossy
Comparing the TL072 datasheet to the LF353 datasheet, I don't see anything there that says one would be any better than the other in terms of output voltage swing or input common-mode voltage range - both data sheets give the some stats. The LF353 has 1 MHz more bandwidth than the TL072 and the slew rates are the same. Both are JFET opamps. And yet one works great and the other one is a poor performer.
Just weird!  :icon_sad:
To answer your title question, no, ICMR and bandwidth are not directly related; however, they may be tied together with some of the internal tinkering that comes about by trying to get ICMR or bandwidth or both to be better. Secondary effects may degrade one while the other is being made better.
There are a number of oddities about feedback amps and unity gain. Unity gain is often the toughest condition for a feedback amp. It's where there is the most feedback, and therefore the most of any problems feedback brings. Some opamps are only stable for gains of five or over, for instance. As you use an opamp at higher gains - that is, less feedback - less frequency compensation is needed, and so the overall bandwidth of the device is improved. Having internal compensation for unity gain is handy, but it's kind of a worst case.
But I think your problem was a bad TL072 or other problem in the general circuit, not a fundamental limitation of opamps or the TL072.
There was a time when opamps in general could be expected to *die* if you exceeded the input common mode voltage range (or differential voltage range, etc.), but modern designs have gotten much better about this. Still, it's not a good idea to trust the opamp to live under all abusive conditions. It's good practice to have external clamps to prevent the inputs from being forced outside the ICMR or IDMR. This is part of the motivation for the parts in the geofex article "What are all those parts for?"
It could well be that the burly, buffered output of your keyboard can provide enough current to damage the inputs of some opamps even with the internal limiting circuits. It's a more likely scenario than many others.
Paul Marossy
Quote from: R.G. on May 09, 2012, 12:33:47 PMThere are a number of oddities about feedback amps and unity gain. Unity gain is often the toughest condition for a feedback amp. It's where there is the most feedback, and therefore the most of any problems feedback brings. Some opamps are only stable for gains of five or over, for instance. As you use an opamp at higher gains - that is, less feedback - less frequency compensation is needed, and so the overall bandwidth of the device is improved. Having internal compensation for unity gain is handy, but it's kind of a worst case.
I didn't realize unity gain scenarios were so hard on an opamp. Good to know for future reference!
Quote from: R.G. on May 09, 2012, 12:33:47 PMBut I think your problem was a bad TL072 or other problem in the general circuit, not a fundamental limitation of opamps or the TL072.
Every TL072 I tried either failed or makes distortion. Maybe it's a bad batch? I reworked the whole circuit, so I know that is good.
Quote from: R.G. on May 09, 2012, 12:33:47 PMIt could well be that the burly, buffered output of your keyboard can provide enough current to damage the inputs of some opamps even with the internal limiting circuits. It's a more likely scenario than many others.
That was my initial thought when I had these problems. The output section of the keyboard uses 1/2 of a JRC4558 dual opamp and then the signal goes through a high/low/off attenuation switch. Not sure of the dB numbers, but I can't imagine that it deals with that much current. How much current does it take to blow the inputs of a TL072? I don't have an input resistor on the circuit, would that maybe help? (only an input cap)
Cliff Schecht
My research is heavily based around designing bad a$$ monolithic op amps, i.e. high bandwidth, high slew rate, anywhere from 1-10A peak output current and as close to rail-to-rail outputs as I can get. In my non-commercial designs I run into all sorts of issues where the bandwidth is directly tied to the instantaneous output voltage. In my case it's because I'm pushing the IC processes to their limits trying to squeeze out as much bandwidth as possible. I've certainly noticed that as I try to push the output voltage closer to the rail (op amp setup as a non-inverting amplifier with gain from 2x-5x) the bandwidth can reduce dramatically, at least if I am swinging with high peak-to-peak signals at high frequencies (where slew rate really hurts).
Some op amps will flip phase if you push the input common-mode signals past their specified ranges. As RG said most modern op amp designs have protection against this but in many older op amp designs (especially those with BJT and JFET inputs) it can be a problem. IIRC it has something to do with how the first stage interacts with the second as you go past the ICMR. This can cause current to flow the wrong way and make the inputs looked flipped from each other. If you monitor the input bias currents they will go up dramatically, something of a tell-tale sign that this is happening (on top of the output being flipped).
Paul Marossy
#5
Quote from: Cliff Schecht on May 09, 2012, 06:11:57 PM
Interesting. In my case, I basically have two unity gain non-inverting buffers in parallel, which makes them operate in a maximum feedback situation. It would probably get better for the opamp if I had a gain of say five, but so far the LF353 is doing fine. I still wonder if a small series input resistor might not be a bad idea to counter too much input current from possibly blowing the inputs.
Get some DC voltages.
I know you are an experienced builder, that you have re-checked the build, but this still sounds like a misconnection.
Paul Marossy
#7
I spoke too soon. It crapped out again last night, made loud popping noises like when it failed before. At this point screw it, it's not worth the trouble.
Just for kicks I did measure voltages on one of the inputs when I put it on the scope, it was almost as high as the supply voltage was.
Paul Marossy
Quote from: PRR on May 10, 2012, 11:43:13 PM
Check DC resistance inputs to ground or Vref.
I did that this afternoon, anything that may be present is well over what my DMM can measure.
I rebuilt the circuit from scratch and made a few tweaks to the circuit, the main one being that I gave it a gain of 10 instead of making it a unity gain buffer type arrangement. So far so good...
brett
Hi
I'm definately no expert, but it seems to me that when an op-amp with less than rail to rail output is presented with an input signal that's nearly rail-to rail, something HAS to give. There can't be enough feedback to hold it at unity gain.
A simple solution for a 9V circuit is to clamp the input using a pair of anti-parallel LEDs across the inputs, trimming the signal to 2 or 3V. In early op-amp guitar preamps (Fender, MusicMan, etc), it was common to see 1N4148s used to trim the input signal (to LM108s, LM308s, etc).
cheers
Brett Robinson
Quote from: brett on May 13, 2012, 07:42:15 PM
That's absolutely correct. The thing that opamp designers have been thrashing over for at least 40 years is to make what happens in this situation be that the opamp flat lines neatly and does not invert phase, latch up and die, oscillate, or other ugly things, and recovers tidily from the overload without sticking, oscillating, yada, yada...
Some modern opamp do all this well. Not all. In either sense.
QuoteA simple solution for a 9V circuit is to clamp the input using a pair of anti-parallel LEDs across the inputs, trimming the signal to 2 or 3V. In early op-amp guitar preamps (Fender, MusicMan, etc), it was common to see 1N4148s used to trim the input signal (to LM108s, LM308s, etc).
Yep. There are several approaches to input limiting.
In fact, before that, the Thomas Vox power amps used a fairly complex (by comparison) limiter before the power amp specifically for this purpose - limit the input so the amplifier doesn't have to cope with over-size inputs.
It's a good approach, and practical.
Earthscum
I latched up a TL072 some time ago in exactly this situation. I also found out what happens when you latch it and take your sweet time poking around for voltages. I blistered my finger, nice little row of 4.  :icon_biggrin:
Anyways, I thought it was something I had done wrong, and blew another chip and pulled the plug on that project. I can't remember exactly what I was doing, but I do remember that I was using it as a direct buffer from a distortion of some kind. So, now that I'm thinking about it (and reading through this) it kinda seems I caused my poor IC's to suffer the same fate as Pauls. The second IC blew with a resistor in line with the input (I think a 10k... all my 10k's are 1% blues... somehow). That is what I had thought was the issue, but the chip went "bbbBBBBRRRRATTTT" and stopped making noise. Just lay there twitching.  :icon_cry: I think I held a candle light ceremony for them, being the first IC's I ever blew out.
Paul Marossy
Ha ha, well at least I know I'm not crazy! It's been a good learning experience though.  :icon_cool:
Paul Marossy
#14
The thing that I really don't get is that I couldn't have been getting an input signal that is nearly rail-to-rail from my keyboard because if I plugged my guitar into the thing, the signal coming from the guitar was definitely stronger than what was coming from the keyboard. I've got humbuckers going thru a Fishman PowerChip preamp, the output level is not much different than passive pickups are, so I can't see that the keyboard was doing more than maybe 2 volts PTP. With a Vcc of 12V it should have had plenty of room to work with, but reality was something different entirely. The service manual for my keyboard says to adjust VR8 on the output amp to 3V PTP, so the maximum output of the keyboard I guess couldn't be more than 3V PTP when output level is set to "high". But when it was set to "high", it was still a weaker signal than my guitar would provide. (I know, I could measure it huh?)
I guess it comes back to perhaps there being too much current from the keyboard output for the opamp's inputs. But that doesn't make sense to me either because I read the other day in a book that the average opamp has about 10mA of output current, and the signal send from the keyboard is coming from an opamp. Surely feeding an opamp with 10mA of "input current" could not fry an opamp's inputs, can it? If that were the case, then any of these cascaded dual opamp distortion designs ought to have failure problems as you're feeding the input of one with the output of another.
The behaviour of this opamp in this circuit I built is still so mysterious to me!
Cliff Schecht
Paul the input current to the op amp based buffer is only going to be as high as needed to bias the input transistors. If you are using a FET based op amp, these currents are in the range of nano to picoamps and is negligible. The only current the output of the keyboard will need to push out is enough to drive the cable and input of the buffer (again this is a TINY current).
Also as far as 10mA frying op amp inputs, it really depends on how big the input transistors are. If you are working with unprotected small-sized MOSFET based inputs then pretty much any overvoltage/overcurrent situation can damage the inputs (the guys in my research group doing ultra-low power medical devices deal with this constantly!). But remember, those inputs only draw as much current is needed to bias the input transistors (known as the input bias current) and therefore for the TL07x series of op amps, nearly no current should be measured going into the "+" pin (probably can only measure this with a picoammeter).
Paul Marossy
Knowing that information, this whole episode is even more bizzare.  :icon_eek:
Cliff Schecht
#17
After a bit more reading I found that the TL0xx series opamps DO suffer phase reversal if the common-mode input gets too close to the negative rail. So if you are using a 9V supply and Vref=4.5V then your signal is swinging down to 3.5V and up to 5.5V. That 3.5V downward swing might be enough to cause problems in UGFB configuration. According to the datasheet the max output voltage for a 9V supply is about 6V P-P (not very good!) and in UGFB configuration the common-mode input voltage is (ideally) equal to the output voltage (meaning since the . If the output clips negative and you get phase reversal from too low CM input, this will typically causes the signal to slam into the positive rail and either latch up or recover (the TL0xx stuff is supposed to be latch-up free though, which they are IME). Sounds like you might be experiencing this, I don't think I have ever though..
Edit: Ha! Just reread the thread and saw Paul said what I was saying already (about the phase reversal stuff). Also I was wrong on the supply voltage, Paul is using 12V which means he should have enough headroom to not be clipping. It sounds like the DC is off somewhere, maybe a leaky coupling cap? Maybe your keyboard is putting out DC? If you really do have the op amp hooked up correctly (not that it's hard :P) then the circuit should work from the get-go. If it doesn't, something else is wrong. I've used TL0xx's as unity gain buffers a thousand times and rarely had a problem that wasn't either user error or something else in the chain causing issues (faulty cables, bad components, etc..).
There really should be measurable DC resistance input to ground/Vref.
With TL072 you "could" go well over 10Meg and be OK; but there's rarely a need to go over 1Meg or so.
With bipolar chips you usually want to see 100K-1Meg or so.
With "no" conductivity input to reference the input bias current will charge-up until the input quits working.
There are a few chips that leak or tend to be self-limiting, will float to a workable point and no further. That may be why the 351(?) works.
> input current to the op amp ...using a FET based op amp, these currents are in the range of nano to picoamps and is negligible
Not negligible if the input reference resistor is infinite. "over what my DMM can measure" suggests over 2Megs which is pretty high.... and we don't know how much "over" it really is.
> If you really do have the op amp hooked up correctly ...then the circuit should work from the get-go.
Right. And Paul is no newbie. Therefore he must be overlooking something in a blind-spot. Lack of input bias-reference resistor is very common in tube-amps, maybe also in opamp work.
Cliff Schecht
QuoteLack of input bias-reference resistor is very common in tube-amps, maybe also in opamp work.
This is a great point! Especially if one is using a DC blocking cap to the input. If you have no reference to ground then the output will start floating into rails. Ask me how I know this...:D
