Gemini III dual fuzz dissected
Started by digi2t, May 16, 2012, 02:15:46 PM
chuckd666
I have a couple MP20Bs for Q1 and Q2, and a Sanyo 2SD187 for the NPN Germ. The Hfe for the NPN is a little lower than I assume it should be. It was around 60-70 I believe.
digi2t
Yeah, if you use what I prescribed on the vero for Q3 gain (100 - 115 hfe), that should bring your voltages into line. You should be able to get pretty close to the original voltages all around.
Dead End FX
http://www.deadendfx.com/
Asian Icemen rise again...
chuckd666
Yeah I figured that must be the culprit. It sounds good at the moment, but might just have to get a bunch of NPNs somehow. Thanks again for the help. A/B'd with my real one it sounds pretty on par.
Zoot
Hello all,
I'm having some slight voltage issues with my Fuzzimile (spaceman gemini iii) build, and I can't seem to find the cause, yet.
Am using the prescribed Russian transistors all within the defined specs. Checked resistors and caps twice.
Everything works, I'm just trying to get to the right biasing point. I can't manage to get Q3/Q6 right, there are much less variation between EBC in my readings, and trimmers can't help. Q5 collector behavior also seems odd.
Voltages are as following (reference voltages from Digi2T in brackets)
Supply: 9.31V (9.05)
Q1
MP20V - Hfe: 84; Iceo:82uA
E: 2.332 (2.044)
B: 2.200 (1.916)
C: 1.440 (1.452)
Q3
GT402V - Hfe:128; Iceo: 95uA
E: 1.720 (1.336)
B: 1.665 (1.174)
C: 1.652 (0.805)
Q6
GT404V - Hfe: 103; Iceo: 270uA
E: 1.720 (1.336)
B: 1.766 (1.416)
C: 1.779 (1.702)
Q4
2N2222A
E: 1.731 (1.238)
B: 2.205 (1.914)
C: 2.286 (3.246)
Q5
2N2222
E: 1.585 (1.726)
B: 2.186 (2.209)
C: 1.775 (2.358)
Q6
2N3700
E: 1.183 (1.136)
B: 1.759 (1.726)
C: 2.291 (2.358)
Q7
2N5088
E: 0.159 (0.159)
B: 0.707 (0.709)
C: 1.669 (1.507)
Any light that can be cast on these voltage variations is appreciated.
Picture shows the transistor in the build.
Thanks,
Zoot
The music of today tells us exactly who we are. We're a chicken-shit bunch of weasels, who like only money, want to be perpetually youthful, live in utter fear of the unknown, and have lost any spark of pioneering spirit. Just a bunch of corporate cowards
