2 Pedals 1 Enclosure, Power question
Started by Aleene, June 09, 2012, 08:10:07 PM
Aleene
Hi guys,
I want to put an SHO and a Klon Buffer into a single enclosure, would it be safe to use the same power DC jack for both, or should I add another one and run them separately?
Apologies if this is a massive noob question or is asked all the time, I have done a ton of searches but couldn't find anything.
As long as both connect the (-) side of the power supply to signal ground, it's fine.
If one wants the (+) power wire connected to ground and the other wants the (-) power wire connected to ground, you get a shorted power supply.
I think you're OK with these as I remember.
Aleene
