How to cut the PCB's?
Started by rmgFX, June 25, 2012, 08:46:10 AM
R O Tiree
Tile cutter, like others have said.  There's a reservoir on mine that you fill with water (for cooling the diamond blade), so there's no issue with inhaling glass-powder dust.
...you fritter and waste the hours in an off-hand way...
Jdansti
Usually a Dremel cutoff wheel, but sometimes I get a decent cut by just slowly nipping with a pair of wire cutters.  When I use the Dremel, I clamp the PCB to a thin piece of plywood which is clamped to my work bench.  The PCB extends past the edge of the plywood so I only cut the PCB. I do this outside with a fan blowing across the work and I wear a face shield.  There's nothing like having a piece of broken cutoff wheel embedded in your neck or eye! :o
Perrow
Dremel + diamond cutting wheel.
defaced
They work ok if you flip them over and use them like a table saw  :icon_biggrin: :icon_eek:
-Mike
Perrow
^ job done!..very efficient too....
Colonel Angus
I was using one of those for a while but I kept on getting FR4 everywhere. Works great for tight corners and neat edges, just keep your pets away from it.
Quote from: frequencycentral on June 16, 2012, 12:59:15 PM
Why should you not have 90o angles? Do the electrons bunch up in the corners?
