UPDATE: Well, turns out I was only using the boost pedal before the distortion and not after. But more on that later.
This pedal was tested yesterday on a Randall Nuno Bettencourt half-stack.
Amazing sound. First it was tested in the front of the amp on the overdrive channel.
The guitar was a beautiful white 7-String Dean RC7x (Rusty Cooley signature model).
The gain setting on the amp was somewhat low. maybe 1/4 or a little more.
As expected, the booster only provided more saturation. But what I noticed was that, to the end of the dial, the booster started to get a little fatter in a very pleasant way. Turned all the way, it provided incredible sustain and a fuzz like sound. very cool.
Having done that, we tested the boost on the clean channel. Wooooooooow
The booster provided and excellent increase in volume before the sound started to get saturated. And when it did, because it was with the boost's dial turned fairly up, we got that nice fat tone ideal for blues or rock. Very nice!
But there was still a big test missing: how would this boost behave on an fx loop?
So today, I tested it at my home, with my amp and my cabinet. It's a half-stack also.
The amp is a Dime Amplification Dime D100 Head.
This amps distortion is not bad but, it has definitely a character that reminds me of Dime's sound. So, I use it with a preamp pedal connected directly to the fx loop return, to bypass the preamp stage of the amp. The pedal is an AMT E1.
The cabinet is a 4x12" with Jaguar speakers. They sound great but are a little scooped. Just have to compensate on the medium frequencies a bit.
I don't know the exact model but the cabinet looks like this
Testing the Boost in front of the pedal gave the expected results: more saturation.
But testing the Boost after the pedal gave me a huge increase in volume!!!!
So much volume in fact that using the Boost with the dial turned all the way down (zero) even gave me a little too much increase in volume for my taste, I should say.
But maybe in the context of a band, this minimum setting is not too much at all...
Yesterday I was checking out some handmade Boost pedals and realized that there are a lot o people using the 2N5088 transistor. I'm using the 2N2222A and getting great results but, would it be worth it to change the transistor to a 2N5088? Or do you even suggest any other transistor? Would the level be more controllable with a 2N5088 (I'm referring specifically to the dial in the zero position and still having too much increase in volume)? I don't need more gain, just more control. Can anyone help on this one? Thanks.
