boss rocker distortion pd1 schematic????
Started by pinkjimiphoton, September 23, 2012, 05:24:08 PM
pinkjimiphoton
hey guys,
anyone got a schematic for this beast?
i got a pair yesterday, so yes, i can compare parts... but it appears to have some weird-ass voltage converter thing that takes 2 c batteries and juices it up to 10v or something.
i can still read the roasted transistor, but i don't know enough yet to be able to identify what to maybe replace it with.
i MAY just convert it to run on a 9v, but at nearly 500 on ebay, i figure i should probably fix it right. the one that works is awesome!!
Slava Ukraini!
~Jack Darr
pinkjimiphoton
the roasted transitor is a 2sc817ay from what i can find... doing a bit of a search, i found an nte equivalent.
but it's really i think just a pnp...do ya think i can sub a 3906 or something?
this is a data sheet for the nte equivalent.
http://www.nteinc.com/specs/200to299/pdf/nte289a.pdf
some of the crap on the board is roasted, hoping the dc-dc convertor thing survived somehow..
Slava Ukraini!
~Jack Darr
pinkjimiphoton
workin on the components, but came across a resistor i've never ever seen before.. it's banded blue grey gold and gold!  WTF???!?!?!?!
Slava Ukraini!
~Jack Darr
Govmnt_Lacky
According to my handy dandy resistor calculator, that is equal to 6.8 ohms 5%  ;D
pinkjimiphoton
grrrrrooooovy!!! thanks! i got that, but there was about 40 zeros on the end of it. ;)
hoping i can revive this poor beast. it's power supply daughterboard got a little crispy  :icon_eek:
Slava Ukraini!
~Jack Darr
pinkjimiphoton
here's a couple pics, i am no good at this stuff, but it shows the parts that are cooked...
gonna try and fix it...wish me luck!! ;)
Slava Ukraini!
~Jack Darr
pinkjimiphoton
awww, shoot, labeled the diode backwards...first pic, where it says + is actually the band/cathode..
Slava Ukraini!
~Jack Darr
Govmnt_Lacky
That black brick has really got me perplexed  ???
Can't find anything on it  >:(
pinkjimiphoton
it's a dc-dc convertor, takes two c batteries 3 volt output, and steps it up to 10v 150ma!
yah, hen's tooth...that's why i hope to get a schematic bro, to see if there's a way to bypass it.
hoping the cheap transistor was there to protect it. there's 3 leads going into it...will have to take some voltage readings from the good one, i guess.
Slava Ukraini!
~Jack Darr
petey twofinger
some one gave me a busted one of those , i think , unless its a boss wah that uses c-cells . i have it here , somewhere .... hmmmm , did i throw it out , crap , i think i did ....
im learning , we'll thats what i keep telling myself
Fender3D
#10
Mine has a 2SA1015 then its central pin is Collector
BTW
get rid of that DC-DC **it...
Get a 7810 or a 7809 + sil. diode on GND pin and use a 12V DC adaptor...
pinkjimiphoton
bside2234 posted this on the other forum...
Slava Ukraini!
~Jack Darr
pinkjimiphoton
Quote from: Fender3D on September 25, 2012, 07:14:45 AM
BTW
thanks federico!!
i'm a dumb newbe...could ya walk me thru that just a little more please?
Slava Ukraini!
~Jack Darr
Fender3D
Get a small vero board and place these few parts
Electros 100 to 470uF 25V, films 100nF
Diodes 4007 or similar.
Unwire the battery box and put it away, unscrew and unwire the stock DC-DC board:
RED wire from DC jack goes to RED on my schem.
BLUE wire from DC jack and Black from main PCB go to my schem. GND
ORANGE wire from PCB goes to ORANGE in my schem.
get rid of the other wires going to DC-DC board.
You should be done...
pinkjimiphoton
federico,
thank you bro,
YOU FREEKIN ROCK MAN!!!!! AWESOME, THANK YOU SO SO MUCH!!!!
Slava Ukraini!
~Jack Darr
pinkjimiphoton
check this out:
http://www.taydaelectronics.com/datasheets/A-915.pdf
if i'm reading right, you could mod the pd1 with one of these, and just use a normal wart. add a 7810, done deal.
Slava Ukraini!
~Jack Darr
