Author Topic: Electro Harmonix The Worm  (Read 9935 times)
Rattlehead
« on: March 06, 2007, 11:37:21 PM »
hi.
i just wondered if you think it is possible to make a footswitch to every mode in this pedal? (it has 4 modes and 1 footswitch)
http://www.musiciansfriend.com/product/ElectroHarmonix-The-Worm-Analog-MultiModulation-Effects-Pedal?sku=153322
Meanderthal
Re: Electro Harmonix The Worm
« Reply #1 on: March 06, 2007, 11:38:44 PM »
 Certainly, the only catch being where on the enclosure to locate them.
Rattlehead
« Reply #2 on: March 06, 2007, 11:41:11 PM »
I think there's enough space between the footswitch on the left and the range knob.
has anyone here tried this pedal before?
does it worth the money?
Barcode80
« Reply #3 on: March 07, 2007, 12:06:07 AM »
decent pedal, but the autowah i expected more of an envelope filter from instead of just a boring set rate sweep. i just scored one for 30 bucks. i am hoping to find some more mods.
Rattlehead
« Reply #4 on: March 07, 2007, 12:09:40 AM »
how's the phaser?
and it's not really analog right?
puretube
« Reply #5 on: March 07, 2007, 01:57:59 AM »
it would only be possible to "footswitch" between 2 modes,
but not between a selected mode and bypass.
it is a very analog circuit - 3stage optical phaser;
(but NOT public domain!).
"autowah" is an often mis-interpreted description;
the LFO modulation was the reason why this pedal was designed upon special request...
pupina
« Reply #6 on: March 07, 2007, 02:41:21 AM »
Another big problem of this pedal is the noise!!!!! It's noisy in every sound you choose....does anyone has fixed this prob?
puretube
« Reply #7 on: March 07, 2007, 05:38:13 AM »
metalfilm resistors...
« Reply #8 on: March 07, 2007, 07:52:40 AM »
Correct me if I'm wrong, Ton, but did the earliest version of the Worm not exist in tube form, before it turned ito a solid-state E-H product?
And just to clarify,
means that if you replace the 5% resistors currently in there with low noise metal film types, you'll get....lower noise!
sir_modulus
« Reply #9 on: March 07, 2007, 08:12:38 AM »
I thought it was the the wahbrato?
« Reply #10 on: March 07, 2007, 08:18:15 AM »
Precisely.
Sweetalk
« Reply #11 on: March 07, 2007, 09:17:15 AM »
I saw a review of this in the EHX DVD, it's nice.. I think it's some "all-you-can-get-from-an-optical-phaser"  :icon_mrgreen: . I'll be nice to add a Expression pedal to control the wah sweep, that i'll be much more usefull!!
puretube
« Reply #12 on: March 07, 2007, 07:36:27 PM »
first, there was the TUBE-PHASER (TM):
therefrom the TUBE-VIBE derived:
the TUBE-VIBWAHTO:
the WAH-CASTER:
(actually a TUBE-CHORUS (TM) with built-in TUBE-TRON (TM) &
built-in 2 x 12W pure tube stereo power amp with stereo-spreading...)
(dual- aka: "Bi-" LFO with the "On-LED/Off-LED" indicator trick to Vb & to gnd...  :icon_wink:)
as well as  the TUBE-WAHBRATO:
at that point, a man (Ted Pierce, demo-guitarist for E-H @ Frankfurt MusikMesse 1998) comes in
and plays the Tube-Wahbrato...
...mentions he needs something like that, with batteries, for street-music...
he especially wants a subtle, cyclicly modulated Wah...
subtle? - OK, leave out 3 of the 6 tube-stages, replace (EMULATE  :icon_razz:) the tubes with transistors,
and add an extra knob to control the resonance
next: M.M. emails he`d love to see such a pedal reduced to 3 pots so it`d fit into a BMP box... :
("Resonance" & "Dry-Wet" set to fixed values, and switched with the "Mode-selector" - that`s the reason why it`s
not so easy to stompswitch the modes)
(also, this switching arrangement calls for a large amount of high-ohm pulldown resistors, that cry for metalfilms...)
a few years later, I "googled" (in fact it was "yahoo`d", back then...) for the WORM (= 3-knob-Wahbrato)
after it was issued by E-H under that name,
and stumbled across this forum, where 3 certain forumites claimed to have the schemo of it.............
NEVER trust a schematic on the web!!!
Schemos for nuttin` and chips fer free?
later again, a combinational mod of the transistor 3-knob/3-stage mod with the original (4-)Tube-Wahbrato
led to the 2-tubed:
(which can be regarded as the legit "Tube-Worm"  :icon_mrgreen:)
[ps: can`t seem to find the `96 pic of the switchable Tube-Phaser/-Vibe pedal, that ought to be between the 2nd & 3rd pic...]
$uperpuma
« Reply #13 on: March 07, 2007, 07:41:22 PM »
so impressive. Just....wow.
RDV
« Reply #14 on: March 08, 2007, 07:25:02 AM »
Bringin' th' funk as usual Tonmeister.
RDV
Paul Perry (Frostwave)
« Reply #15 on: March 08, 2007, 07:39:19 AM »
Nice to have the Word on the Worm :icon_smile:
I guess MM knows his market - but it's always sad to see a couple of useful controls forced out.
DWBH
« Reply #16 on: January 05, 2009, 04:05:56 PM »
Lets bump this.
The big enclosure Worm has been discontinued, having since been replaced by an XO version (BB sized diecast box). One (and I think the only) difference between these two is that the most recent version has an Expression pedal input.
Does anyone have a schematic for either (or both) pedals, so I can implement the EXP jack on an older versions?
puretube
« Reply #17 on: January 10, 2009, 06:51:31 PM »
here`s your answer...
