Need: A definitive solution to zombie and Ultra Flanger
Started by gorohon, December 01, 2003, 01:24:05 AM
Maneco
hi,
regarding pin 5,just leave out the pot and 100n/10k series,they are the regeneration path...but you coulkd add it to get some extra effects from the chorus...i also suggest that you  replace the buffer stage of the zombie with the full audio in path of the tokai,the same for the output expander,wire it after the filter stage of the zombie and copy all the rest of the circuit,maybe shortcutting the fet for adding a true bypass a la millenium...
all the best
Maneco
good luck,i know you can do it...
gorohon
Thanks again, Maneco.  I'm going to go ahead and build a completely separate zombie to do all of these ideas.  First order of business, go buy myself a good breadboard.  Second, get started.  I'm going to shoot for a completion in March, as I have some other personal goals to accomplish first.  But whether success or failure, I'll report back.  Idlefaction, your chorus sounds interesting.  You ought to post the details of your customized delay-turn-chorus effect.
"Come on in...I've got caaandy!" H.S.
gorohon
I just looked at your manecolooper and microlooper.  I'm a big fan of Robert Fripp and his Frippertronics stuff.  I imagine that one could do similar stuff with your effects. Maybe, down the road, I'll buy one of your creations.
Maneco
thanks for your feedback on my machines...
what i ususally don´t use is a breadboard,i try everything on soldered perfboard,but that's my way of doing things...
gorohon
I've never used a bread board before, maybe I should just stick with what I know.  Plus, I could use the money to buy parts instead of the bread board.
