9.1 volt zener question
Started by Russ, January 27, 2004, 11:35:09 PM
Russ
Hey guys,
What wattage 9.1 volt zener do you need to use in connecting between the gate and source of a BS170 transistor (such as Jack's Mosfet booster, etc.)?
Is 0.5w okay, or does it need to be 1w?
Russ
Peter Snowberg
1/2 watt should be just fine. The zener is only used to protect the gate from static so the actual current is VERY small, but the voltage is HUGE.
Best of luck on your boost!
Take care,
-Peter
Eschew paradigm obfuscation
Russ
Thanks, Peter, I appreciate the info.
Russ
