FireFly tube amp
Started by ErikMiller, March 09, 2004, 07:39:38 AM
ErikMiller
I feel weird putting "OT" in front of a topic that is so often discussed around here.
Can't we just say that the FireFly is an "effect." :-)
Anyway, I'm having trouble with a couple of components, resistors actually.
R13 is called out as a "440" ohm resistor. I have a pile of 470's, and even a few 430's, but the 440 is a rare beast indeed. Is this value that critical? Or do I need to take one of my 430's and put it in series with a 10?
Also, the cathode resistor, 1.8K seems something of a rarity in the world of 1/2W resistors. Is it really taking that much power? I suspect it might, being on the cathode and all....
I'm really excited to get this thing going. Building a tube amp is a whole other level of DIY-itude, one that I've been wanting to check out for over 10 years.
Lurco
440 = 2 times 220, if this helps.
Absolutely don`t know which circuit you refer to,
but maybe it`s a questionf of parting voltage or
power over the shoulders of 2 resistors?
smoguzbenjamin
You don't know the firefly! :| You need to check out Doug's site! Uhm... I don't know the URL but try ggoling for "Doug hammond firefly" that should get you some results.
Doug H
Quote from: ErikMillerR13 is called out as a "440" ohm resistor. I have a pile of 470's, and even a few 430's, but the 440 is a rare beast indeed. Is this value that critical? Or do I need to take one of my 430's and put it in series with a 10?
I used 2 220's in series for the 440. 470 should work fine, I just didn't have any on hand and drew the schematic the way I built it.
You should be able to get 1/2W 1.8k resistors at mouser. As a rule, I use at least 1/2W resistors in tube circuits.
Doug
Paul Marossy
I used a 470 ohm instead of the 440 ohm, and it sounds fine to me.
For the 1.8K, I used a 1.5K and a 330 ohm in series, which gets you pretty close to 1.8K
Most of my resistors are a couple in series to more or less match the schematic, I just didn't have most of those exact values lting around...
