what are the all time simplest pedals to build?
Started by tele_guitarist, March 24, 2004, 11:14:24 PM
nightingale
bazz fuss~
great sounding fuzz too...
www.runoffgroove.com
be well,
ryanS
www.moccasinmusic.com
Ansil
Tim Escobedo
Nasse
Peter Snowberg
Eschew paradigm obfuscation
lightningfingers
muff fuzz
it was my first build and i still use it
sounds great
U N D E F I N E D
Oliver
try this..... (perhapst some Partvalues may be different for Your Taste)
bye
Oliver
Only dead Fishes go with the flow... >-))))-°>
Ge_Whiz
In order of cost:
1. One Schottky diode across the guitar plug.
2. Two Schottky diodes in anti-parallel across guitar plug.
3. One or two diodes as above with switch.
4. Feedbacker (only works with other effects).
Ge_Whiz
5. Brightly painted, sealed, empty box with two sockets connected straight through and an unconnected footswitch. Will sell for $$$ on ebay and will have guitarists crowding around saying how much they like the subtle tonality.
Nasse
Marcos - Munky
The Bazz Fuss is the most simple that I saw. Or you can check my site and see the Double Jam, the most simple dual channel overdrive that I saw. And you can build it using only one channel, then you need only two caps and a LM386!!!
MattAnonymous
Easy Drive is the most bang for the build!!
It's people like us who contribute to dead fx pedals selling on eBay for what they'd cost new!
travissk
A stutterbox perhaps? It's in the same category with the true bypass loop box, or the feedback loop box.
After those projects, the Bass Fuzz and related simple fuzzes are good choices. I don't have any experience with the Easy Drive or Smash Drive, but there are quite a few good, simple pedals.
Fret Wire
Tonepad's Dist.+/Microamp. They have a dual layout board that can support either build. Since it uses a dual IC (4558), you can mod it to death between the IC's, diodes, and cap values.
Fret Wire
(Keyser Soze)
brett
The bazz fuss is a great circuit for so few parts.  Now here's my "secret" formula:  add Big muff tone output sections you get a distortion pedal to rival any, and with a parts count of around 15.
Brett Robinson
