Tone bender mk III; WIP
Started by Steben, November 05, 2022, 07:24:35 AM
Steben
Hi guys,
I'm about to finish an mkIII and was wondering whether some of you could tighten up my flood of thoughts. You see given the fact I have pin sockets I want to fiddle with some transistors here. Probably trying to use as much silicon here as possible without changing the character.
Two elements are fixed though:
- I'll use the fixed resistors in the darlington stage
- the third transistor will be germanium.
Fuzzcentral mentions 2n3906 for example as silicon alternatives for q1 and 2. I have some so i'll try them first. Some BC559A's can be used as well.
radio
The short lived PCB BLM Fuzz was a kind of rangemaster and silicon tonebender 3 in one.
https://www.godcityinstruments.com/collections/diy-pcbs/products/blm-fuzz
I just post it as seems he gets away with only using a germanium diode with the 2N5088
to fake a bit of germanium caracteristic. ( I know its called fixed bias configuration
but not understanding whats the exact result is)
Keep on soldering!
And don t burn fingers!
Steben
Quote from: radio on November 05, 2022, 04:49:53 PM
Well yes, this one uses a resistor from collector to base so Q3 does not need leakage.
radio
Ah ok, now I understand that!
A simple "mod" I did to the TB3 variant of Tobias Carlson,the Tone Burner,many years ago
http://www.generalguitargadgets.com/pdf/ggg_tb3tb_sc.pdf
I didn't put C11 on the switch ,so on that position there was no bypass cap on Q2 emitter,
giving a lower gain fuzz as an option.
Keep on soldering!
zbt
Perhaps change Q1, Q2 circuit like Fuzz Face, blend the output like Fuzz Rite :)
zbt
Waiting for Why John Why chapter 3
Still WIP ?  ;D
Steben
Quote from: zbt on September 16, 2023, 05:02:53 AM
Still WIP ?  ;D
:icon_mrgreen:
ow yes, board is soldered.
Funny thing is I recently said to myself man this needs to be dealt with.
ANd I DO have a great stompbox enclosure for this.
zbt
Just relax and be enthusiastic, who knows, you might get enlightenment  :)
Steben
Dry Fit Baby....
Again movement in the project.
zbt
The secret of Tone is Timbre  :icon_mrgreen:
Found this board a bit confusing MK3 MK4 around Buzz
also see other bigger board
Steben
Steben
All fit, voltages ok. Sound no...
Damn, classic debugging  8)
Steben
