Build a DC voltmeter into a pedal for seeing bias?
Started by Toy Sun, February 24, 2023, 09:27:47 PM
Toy Sun
Anyone ever try it? Sounds fun. Easy to get a cheapo voltmeter module from ebay...
Thanks,
John
GibsonGM
I think many or most of us have looked at the bias of a pedal with a DMM...inserting one into your pedal should be very easy to do, if you wanted, tho it would probably just read that one value all the time, so it would be 'gimmicky'.   An exception might be if you did this with various fuzzes with a bias control, such as a Mosrite Fuzzrite, where changing bias IS a useful feature (tho usually just done by ear).    Try it out! :)
The pot position already tells you the bias.   If you calibrated the extremes of the pot and labelled them the interior pot settings could be eyeballed from the pot position.  (All assumes the battery voltage is constant.)
I have always wanted to build a power amp in a valve cover of a car and use the oil filler cap hole as a place to mount an analog meter.  If you build one, you can be satisfied that no one else has one like it.  Cast aluminum valve covers make great heat sinks. And they are shielded.
I'm all in favour of adding a digital meter to a stompbox and a bias control is a great reason to do so.
Toy Sun
Thanks for the feedback and links. It's true, this is only something to consider where biasing really impacts the tone. And for sure, knob position will tell you where you are set (doh!).
Phend
  • SUPPORTER+
Phend
#7
Dug this up, have .., not a pedal, haven't built one but could be put in a Stomper .
  • SUPPORTER+
phend: looks like he put a cheap DSO 150 scope in there....
how do i know?...i have one.  8)
Phend
Actually the DSO 138 model. It has no enclosure like the 150. Just bare bones.
Had to make standoffs and special buttons. Cut the square hole in the face plate etc.
Cost $28.99 usd for the scope.
For $16.99 you can get 10 of these..
  • SUPPORTER+
FiveseveN
My assumption was that you'd put the display in a temperature-sensitive (Ge) circuit so you can tweak it to some "optimal" value under different circumstances. And of course there may be more than one preferred value/range.
Here's a commercial example: https://www.silktone.org/store/p13/fuzz.html
Quote from: Rob Strand on February 26, 2023, 07:31:34 PM
I always thought Keith Emerson's setup was cool.
https://www.synthtopia.com/content/2014/04/25/moog-music-intros-new-emerson-modular-system/keith-emerson-modular-synthesizert02/
person on the left seems to think it's a theremin.
this digital voltmeter in a fuzz or similar idea - this would be a circuit with a multplexed display, spewing out digital noise left and right, wouldn't it?
