Noisy Cricket
Started by Box_Stuffer, March 07, 2025, 09:51:58 PM
diffeq
Box_Stuffer
#22
Quote from: antonis on March 13, 2025, 04:40:37 AM
Quote from: Box_Stuffer on March 12, 2025, 09:04:20 PMIt needs to be louder for sure.
2kW peak is enough..??
Actually, I think I need 1.21 gigawatts and I might have to use the local clock tower to harness a lightening bolt.
Box_Stuffer
So in this case , how/where do I attach the capacitor and piezo?
if you are running a piezo disc from a 555, you don't need any power. put the disc into the bottom of a 35mm film canister, and then POINT IT at something. see if it's loud enough then.
printer2
35mm film canister? What is that?
Fred
Box_Stuffer
Quote from: printer2 on March 14, 2025, 11:09:59 AM35mm film canister? What is that?
Those are what people used to keep their weed in.
Box_Stuffer
Quote from: duck_arse on March 14, 2025, 09:43:21 AMif you are running a piezo disc from a 555, you don't need any power. put the disc into the bottom of a 35mm film canister, and then POINT IT at something. see if it's loud enough then.
I considered something like that, but it needs to be as inconspicuous as possible. It may have to be duct taped to the bottom of a counter or hid in a tight space. I think I have some of those shot glass size plastic solo cups. i could experiment with one of those.
phaeton
Long long ago, in a galaxy far far away (Usenet) I asked a similar question of "how to get longer delay (like 16-24 hours) out of a 555?".  My goal was to get a long delay, then briefly power on some noisemaker to annoy some co-workers.
The answer was ultimately to use something like a CD4060 (binary ripple counter).  I tried digging up the old Usenet post (someone there even provided a schem) but I've been unsuccessful.
In any event, to get longer delays, maybe having a CD4060 doing the count/delay part, and having it briefly turn on whatever circuit to do the annoying is the key?
Stark Raving Mad Scientist
for 16-24 hours, any mechanical alarm clock should be fine.. :icon_wink:
Check out the µA2240 which is a 555 - type astable oscillator attached to an 8-stage divider with open collector outputs.  I once replaced the guts of an organ with a board containing 12 of these.
https://www.datasheet.support/pdfviewer?url=https%3A%2F%2Fpdf.datasheet.support%2Fc7342c7a%2Fti.com%2FUA2240CN.pdf
3 bucks a piece; can't beat that.
"Cricket Noise Maker Prank (6 Pcs), Hidden Pranks Beeping Several Months, Funny Office Pranks"
https://www.amazon.com/NewNoiseWar-Cricket-Hidden-Pranks-Beeping-Several/dp/B0D7H6DPBM
4.6 stars
'This product has fewer returns than average compared to similar products.'
They also have: Joywhiz Cricket ....with Remote Control; and Prank Device That Won't Stop Beeping for 3 Years
