Can a JFET sub a MOSFET?
Started by crawler486, May 04, 2004, 10:51:05 AM
crawler486
I can't get any MOSFET transistor for the Millenium Bypass
Im building.
Can I replaced it with just a JFET?
Thanks.
gez
You can use one of the MOSFETs in a 4007 chip (easy to come by).
Failing that, there's a JFET Millennium (the original) over at Geo.
crawler486
brett
Hi.
Here in Oz the 2N7000 MOSFET seems more common than the BS170.
In the Millenium 2, you might try a Darlington (e.g. MPSA13/14) instead of the mosfet.  I *think* that'll work.
Brett Robinson
crawler486
Quote from: brettHi.
wow..I hope mpsa13 works.
I got 2 lying around
thanks..
Transmogrifox
You can usually sub most MOSFETs for MOSFETs.  Just double check your bias conditions and you'll likely be ok.
JFETs, the same.  If you know what the biases should be, you can sub.
You can also sub BJTs if you know how to change the circuit for the correct DC bias.
Any changes will likely change the sound.  MOSFET--->JFET, subtle difference, noticeable though.  FET--->BJT, likely very big change.
trans·mog·ri·fy
