treble booster
Started by thomas2, August 06, 2004, 11:21:06 AM
thomas2
does anyone know a treble booster i could build using 2n2222 or j201? those are the only ones i've got..
i'd like to make the brian may booster, but i haven't got the right transistor. there isn't one shop here where i could buy components.
it would also be nice to know if it's possible to make it boost mid's instead of treble
sorry again about my crappy english  :lol:
tee se itse tai kuole
petemoore
Links>Guitar Effects Projects> scroll; Effects Projects>Boosters and Routers..
 J. Sleep has a nice selection of boosters.
 Socketted transistors [if you got e'm] because the LPB I think likes low noise transistor, and Jfets are somewhat inconsistant.
 Stratoblaster uses a Jfet.
 Runoff Groove's Fetzer Valve is great and easy... close enough to no current flows through the gate of the Jfet, therefore no input DC blocking / Highpass cap is used...the [only?] way to reduce bass is with the output cap that I know of....I tried once adding the increasingly teenier input cap values on a Jfet Boost..seeemed inneffective.
brian wenz
Hello Hello-
   Try Jack Orman's "Muffmaster" at the AMZ site.   You can increase the value of the input cap. if you want more mids.
Brian.
Ed G.
Make a minibooster using J201's and reduce the cap between the gate and source of the top fet for a treble booster. Should sound fantastic.
Doug_H
