A circuit to aid my amps's effects loop?
Started by John Egerton, August 20, 2004, 12:35:20 PM
John Egerton
Hey guys,
I was wondering if you could help me with this problem...
I own a marshall mode 4 and i use it in conjunction with the effects loop which contains various pedals that are both true bypass and not.
I also use a fuzz factory that goes directly from my guitar to my amp...
On the mode 4 is an effects loop level knob that will increase/decrease the volume of the pedals in the effects loop to their relevant volumes...
I like the effects in the loop to be at the level they would if they were in the primary chain which invlolves turning th knob to max.
However when I increase the effects loop level, my fuzz factory looses both a little volume and tone...
I was wondering if there was something that I could place in my effects loop to prevent it from doing this?
John
Save a cow... Eat a Vegetarian.........
niftydog
build a modified boost pedal, ie; make an active volume control with some gain. Then, use that to boost the level coming out of the effects loop.
niftydog
Shrimp down the pants!!!
“It also sounded something like the movement of furniture, which He
hadn't even created yet, and He was not so pleased.” God (aka Tony Levin)
