OT: NiCD to Lithium battery conversion
Started by Gil, May 13, 2005, 07:15:47 AM
Gil
I'd like to convert the battery circuit in my Kawai SX210 synthesizer so it can use a Lithium battery instead of the (stock) NiCD battery.
Can anyone tell what should be done ? as far as I understand seeing conversions done on other synths, the 1.5K resistor connected to the battery should be replaced by a 1N4148 diode, with the diode's positive side facing the battery's positive side ?
Gil
Nasse
What I know lithium-ion cells need very "intelligent" charger... special chips and temperature sensors and such, so it might not be easy
Just my 2 pennies
Gil
Thanks, it's not a lithium-ion but a  regular Lithium - no chrarge needed.
niftydog
Can't say I've ever heard of a plain Lithium battery, I've heard of lithium-polymer and lithium-ion though. Can you elaborate?
//www.batteryuniversity.com might help.
Be aware that if you DO use lithium-ion that they can be quite dangerous. They require specialised charging circuitry as well as current limiting and over-discharge protection.
niftydog
Shrimp down the pants!!!
“It also sounded something like the movement of furniture, which He
hadn't even created yet, and He was not so pleased.” God (aka Tony Levin)
Nasse
Yeah I believe he means those very nice and powerful lithium button cells, it was clear in the question but I fuzzed it. If I understand keyb/synths use a battery to maintain your sounds and settings when power is off. A Ni-Cd can die by age and accidents, and needs regular charging, so new equipment use those lithium batteries for simple and reliable performance. My Casio CZ-1000 has regular batteries, the big ones, and lots of them. When kids laughed at my old synthesizer I lied that Van Halen "Jump" was played with a Casio CZ-1000, and they believed me, their eyes and mouths were wide open...
Quess some kind of diode trick could do the job. Maybe a schottky diode can be used for less voltage drop, or you could adapt a P-channel mosfet for almost no drop...
niftydog
Ah ha, Lithium Manganese! Duracell brand them as "Duracell Ultra."
niftydog
