Ruby Amp W/ Bassman mods Outboard wiring
Started by normy, April 06, 2008, 05:07:35 PM
normy
hello I'm trying to build a miniruby amp with bassman mods
i have finished the circuit yet i am confused how to wire the offboard wiring
i used the schematic and layout from runoffgrove and the bassman instructions
and i am using a 50k volume pot
i just do not know where to hookup the offboard wiring
any help would be greatly appreciated
        thanks
bkanber
You may want to check out the links to DIY FAQ and GEO FAQ at the top of the page first. If you still have additional questions or confusions, come back with a more specific question and we'll be able to help you. :) The FAQs above are pretty comprehensive, and should cover any outboard wiring questions you have.
Burak
Burak
momo
I just want to chip in here and say that for me the bassman mods are the best version of the Ruby!....especially for smaller sized speakers. I tried it with different sized speakers and it does sound fuller when using say a 4 inch speaker.
My main Ruby setup uses a vintage 8 inch and its really good.
Cheers
"Alas to those who die with their song still in them."
gutsofgold
I also like the bassman mods. Since it is such a small amp, I wanted it to be as simple as possible and the one knob setup was perfect. It really has a bassier tone and the overdrive is actually warm and enjoyable.
The perf layout shows every offboard wire here
http://runoffgroove.com/ruby.html
It doesn't list Volume Lug 1 but that goes to ground.
normy
normy
ok so i hooked up everything but there is a problem
when i plug the cable in and turn on the amp there is a buzz
as I turn the volume pot up the buzz got louder and higher pitched
  so now i need some help on how to debugg this problem
  please help
thank you
bkanber
Are you getting sound for the guitar or not?
If you ARE getting guitar sound, then probably something isn't grounded.
If you are NOT getting guitar sound, then you miswired something. Look through your wiring and the schematic again.
It's easy to make mistakes if you user a perfboard and not PCB.
Burak
